uc320w with isdn (uk) missing leading zero
Matthew Needs
Hello, we have configured a uc320 in the UK with the mediatrix 4400 for isdn bri access. The uc has been fully upgraded with the latest patches and incoming/outgoing calls work fine. However, when an incoming call is missed the number displayed on the handsets is missing the leading zero? This means that a customer number redial fails... How do we get around this? I see that the mediatrix is capable of digit substitution. But is this a recommended course of action? And is there an example config available to confirm things?
Many thanks
Matt
Jo Kern
for incoming ISDN calls please try the instructions here:
https://supportforums.cisco.com/docs/DOC-20771
For incoming SIP calls you might want to ask your SIP service provider if he can add a 0
I will keep you posted when a better solution will be implemented on the UC320W.
Jo
6 Replies 6
Julien Paleni
I'm in France and i have the same problem. My uc320 is set up with a sip trunk and just like you, the leading zero is missing for redial.
Does-it possible to have a pmf file to correct this ?
Jo Kern
Jo
Thanks Jo! Great detailed info... We'll be testing this shortly and will keep this thread updated with any developments.
Kind Regards
Matt
Jo Kern
Hi, here is a workaround on how to dial numbers from the "missed calls" menu on the SPA phones on a UC320W.
Not perfect but quick and you can steer your calls easily out a different trunk if you like.
Otherwise re-configure the Mediatrix to automate this as mentioned in my other post.
Step1:
Open the missed calls menu, press "Miss"
Step 2:     Select the call you want to return, the newest missed call is on top of the list:
Step 3: Since a leading zero is missing , you just press 'edit dial'
Step 4: The cursor is already at the beginning of the number. Just press the keypad with the required digit . Let's say '0'. And then the 'Dial' Softkey on the screen. You added the second zero and dialed with 2 key presses.
It is not one click but it is quick.
Jo
Thanks for your help.
I will contact my SIP service provider and see if he can add a 0 on the incoming call.
Adding the 0 on the phone before calling, it's a little complicated for the end-users...
Matthew Needs
Just for forum completeness.. This solution worked perfectly for us! Thanks again..
Matt
