Showing results forĀ
Search instead forĀ
Did you mean:Ā
UC500 - 886va branch offices
nextp
Good afternoon
I am thinking of implementing a Unified Cisco Communications environment.
I will use UC500 on main office and 886va-e-k9-wlan on branch offices.
In branch offices i will user  Cisco SPA502G phones. Can i plug the phones directly to 886?
How will they operate-aquire their settings?
Thanks in advance
If you use the CME from the UC500 you can use the SPA phones a the branch. If you will use the CME from the 886 it isn't possible, because the SPA phones are only supported from UC300 and UC500 series.
Perhaps it's possible to use it with a default SIP configuration.
best regards
Christian
- Please rate helpful posts -
