uc500 and spa942
nguyentom
I am setting up uc500 to work linksys spa942.
I got them working as far a in and outbound calls.
I am struggling to get one important feature to work and that's voicemail.
the uc cue works fine becuase I can call it from a 7961 phone.
when I call voicemail from the spa942, the phone displays "not implemented"
when make call to the spa942 phone, it just rings forever.
thanks for your help!
Tom
This configuration is not supported, but if you want to make it work, you need to add a user and a voicemail box for that user in CUE. You can use the native GUI for this, at 10.1.10.1.
Marcos
luissgl
Did you make work UC500 with spa942? how you did it? i have the same problem
