01-25-2012 02:19 PM - edited 03-21-2019 05:15 AM
HI
I wonder if anyone has had previous experience of integrating a Cisco UC500 PBAX with a Polycom SIP Server, I've seen that you can integrate with CUCM versions, but I wonder if you can integrate with the UC560.
thanks
Solved! Go to Solution.
01-25-2012 03:51 PM
Hi Arturo,
In theory this is possible, but not supported.
You need to do it via CLI and creat a SIP DN ( SIP end point) which makes the polycom an extension.
That's the only way I know how it can be done..
(PS) I think you may have double posted so can you please delete the other one
Cheers,
David.
01-25-2012 03:51 PM
Hi Arturo,
Cheers,
David.
01-26-2012 12:45 PM
Hi David
thanks for your response, and a SIP DN is matched as the CUCM server and Polycom 6000, from what I read in books. But with the UC560 with CCA application is not possible.
When did this project I made this question of cisco engineers, and they told me that it was possible integration between the two systems through a SIP trunk.
could be linked by SIP TRUNK?
thank you very much, a greeting
01-26-2012 12:57 PM
Hi Arturo,
I believe when they say SIP trunk they mean setting up a SIP-DN.
However if they do actually mean setting up a SIP trunk, I believe you will
have a hard time attempting this as the Polycom 6000 would need to act as a
server or an SBC, and I highly doubt that it has that capabilities.
I would look @ CCA 3.2 and see if it supports the creation of SIP-DN's now
and if it does that is still going to be your most likely way of linking
the two systems together.
Cheers,
David.
"Sent from my Acer Iconia A500"
01-26-2012 01:28 PM
hi David
thank you very much for your quick response CCA version 3.2 is that I use to configure the UC560, and I see or encounter where you can configure a SIP-DN, I would be helpful if you or a colleague of yours can I check whether create a SIP-DN with CCA version 3.2.
Should this be possible please send me a message.
thank you very much
regards
01-26-2012 01:52 PM
hi david
sorry for the confusion, the CCA version I have is 3.1. (1).
is now available in version 3.2?
thanks and greetings
01-26-2012 02:09 PM
Hi Arturo,
3.2 is available for download as far as I am aware, not officially released
as there has been no announcement and I have not downloaded it yet.
I don't know if this will do what you want, it is just a suggestion as I
haven't seen 3.2 yet myself, I just heard whispers that 3.2 just maybe will
support the creation of SIP-DN's, but it may not.
Cheers,
David.
01-27-2012 03:51 AM
hi David
I updated my CCA to version 3.2, and after several tests and analyze the new version, I think it is possible to make SIP connections - DN, if I have seen that there are updates and new SIP SIP providers, but to do SIP Trunking SIP TRUNK not for links - DN. would be possible for someone to ask me to confirm that this version 3.2 is not possible to make SIP connections - END POINT?
If you can not configure a SIP Trunk - DN from CCA. I wonder how it can be programmed via CLI, and if possible support to make this link.
thank you very much and best regards
01-27-2012 04:58 AM
Hi ARTURO,
Sadly I cannot do any testing for you as I don't have access to any
equipment, you may need to see if someone else on these forums can assist
you with this
Sorry...
Cheers,
David.
