08-11-2012 06:04 PM - edited 03-21-2019 06:09 AM
I have a customer that is using Truckmate, produced by a company called TMW. Has anyone done integration of this software with the UC560 as the customer wants to integrate their database.
thank you,
sanjit
08-12-2012 03:05 AM
In practice, what is that your customer wants ?
08-12-2012 12:27 PM
Hi Paolo,
The customer is looking at the UC560 solution. They have a database of their customers on the Truckmate solution. When a call comes in, they want the calling number to pull up their customer information on the screen from their truckmate solution. Is this possible with the UC500 ?
thanks very much,
08-12-2012 02:55 PM
You have to ask the software vendor about witch protocol they interface the phones system, for example TAPI, that is supported by the UC500. If they just want to launce a web page based on calling number, you can also use the TAPI Web Launcher that I wrote and can be acquired from my website - mentioned in my profile.
Note unless you have previous experience with telephony and networking, it is recommended that you engange a certified Cisco partner, or person with equivalente knowledge and expereince, for both the pre-sale and deployment of the product.
08-12-2012 03:20 PM
Paolo,
Thanks very much. I'll check with the vendor. Yes, it would only be carried out by a certified partner, if it is a workable solution.
thanks again.
