UC520 creating vlans not routing to internet
Frank Henderson
I'm having a problem with a UC520 not routing properly.
I currently have 3 vlans. The two created by the UC,plus an addition vlan for retail customers.
I'm able to connect and route data between the data and the retail, but when I try to get to the internet from the 3rd vlan, everything times out. The current configuration, is a uc500 connected to CE switch, and ap. The uc is connected to an asa 5505.
any suggestions?
David Trad
Hi Frank,
Can you please post your config with all sensitive information removed, it is a bit hard to provide you some reasonable answers without first knowing what exactly has been configured, we could stab in the dark but then ends up becoming somewhat frustrating.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Make sure you have NAT in place for that new VLAN.
Marcos
