Resolved! How to set KSA date and time
Hi I am trying to set KSA date and time using CCA2.0 ,but i din't see the KSA time zone under date and time setting so how to fix to correct the problemThanks
We just installed a UC540 for a company. The dial by name and dial by extension is working fine. The company is a marketing and PR company and each employee is in charge of one or multiple accounts. My clients would like their system to be set up suc...
Hi all,I have question regarding steup corlist on Cisco UC500 with CLI.Outgoing calls are routed via a SIP trunk from a generic SIP provider.There is my config :dial-peer cor custom name national name gsm name international name urgence!dial-peer cor...
Looking for some documentation on "Group Paging" on the UC540. Searched the community, but could not find anything specific. Any assistance is appreciated.Thanks, Jared
Hello... is there a default timer on the UC520?Conf calls users are complaining that the calls drop after 60 minutes. The provider checked their settings and suggests the problem is on the UC520.Thanks. Vincent
Hi, i have an UC520 and created a Hunt Group with several extensions and i want to make them ring at the same time not just sequential or random. Could this be possible and if so please tell me how to doit?. Thanks in advance.
I need 4 custom scripts. They are very basic ones that can be created in CUE. Also, I have the aa_transfer script loaded. When I create script #4, it says I cannot create because the maximum number of scripts has been reached. Is there any way ar...
I am sure this is a basic, elementary networking issue but I cannot get my head wrapped around the problem. My network is 10.0.0.0 Netmask 255.255.255.0The UC-520 is 10.0.0.2. The phones are 10.1.1.0 Netmask 255.255.255.0. I can access the CCME at 1...
It is not necessary to insert phone license in the UC500 devices? CP-5xx, 79xx, SPA 5x ....
Using the guide for UC500_onramp faxing, I get to the step where I add the parameters for the fax detect application. I get a message "Warning: parameter fax-dtmf has not been registered under fax_detect namespace. I get the same message when tryin...
We have a feature from our telco called Call Transfer. If you flash the line you will get a dial tone, then you can dial a #, flash the line again and then hang up. This allows you to transfer your caller to a third party without tying up 2 phone lin...
How do you ignore or send an incoming call to voicemail? On Polycom phones a soft button appears that says reject. This is very helpful if you are already on a call and get a second call to stop the phone from beeping in your ear. I can't find any...
Is there a way to bulk import a System Speed Dial list?I tried editing the speeddial.xml and 'uploading' it but that doesn't work.
Was in CCA ( 2.1) > Configuration > Voice > User Extensions.Made a change to my extension for testing Button labels.When I clicked 'Apply' In addtiion to rebooting my phone, other phones throughout the company rebooted. Luckily none that were in use ...
Error Description from Primary Event Dailog box:Description: VLAN Interface Settings are not synchronized across the following devices:MobilSat-SW-02, MobilSat-SW-01, MobilSat_UC520Recommendation: Click 'Resolve' to open the 'VLAN Interface Settings'...
