UC520 CUE Install
thalfpop1
I've tried reloading and installing with the boot helper, but everytime I session to it I get this error:
ReiserFS: warning: is_tree_node: node level 0 does not match to the expected one 3
ReiserFS: hda1: warning: vs-5150: search_by_key: invalid format found in block 32803. Fsck?
ReiserFS: hda1: warning: vs-13070: reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [1 2 0x0 SD]
ReiserFS: hda1: Using r5 hash to sort names
ReiserFS: hda1: found reiserfs format "3.6" with standard journal
ReiserFS: hda1: using ordered data mode
ReiserFS: hda1: journal params: device hda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda1: checking transaction log (hda1)
Any ideas?
2 Accepted Solutions
Well, fhe Cisco code may not like the specific hardware or size of the new CF.
In one occasion I was able to replace a failed AIM-CUE disk with a generic one, but it wasn't an UC500.
See if you can 'disk erase' the original one and have it work instead.
Hi Tyler,
Hate to be the bearer of bad news, but the CFC you put in there is too big,
2GB is the maximum I have been able to get to work. Also Transcend and
KimgMax are the most compatible with the UC, whilst Sandisk are top of the
range, I havent gotten one to work correctly with the UC, even on the CME
side.
On Apr 8, 2012 6:59 AM, "thalfpop1" <
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
17 Replies 17
paolo bevilacqua
Try removing the CUE flash and 'zeroing' it on a PC. Hopefully that will make the disk formatting work better.
David Trad
Hi Tyler,
That's a sign that either the CFC has gone bad or the CUE/DB Has become fully corrup that you can No longer Install to it again.
Two options:
1. Do as Paolo Suggest and Get windows to repair the CFC if it is repairable
2. Purchase a new Transcend or Kingmax CFC and start from scratch again
I hope this helps :-)
Cheers,
David.
If you format the card in windows, and it scans fine. The card is fine i am assuming. But during the installation I have
Unable to read /dev/hda
mkreiserfs 3.6.19 (2003 www.namesys.com)
Failed to open '/dev/hda1': No such device or address.
mount: you must specify the filesystem type
Any Suggestions?
thalfpop1
Thanks guys for the help.  I got a new CF card and completed the first step with the boot helper.  I am at the final step and not able to do the ftp.  Any help would be much appreciate!
I should add I tested the FTP from another machine and that worked fine.
I just can't connect to the the module.  I got an error after completing the initial tftp that said:
Waiting for IOS to register IP address.
- waited 15400 seconds…
I had the service module configured just with an interface and used that as the DG and entered a different address as the address in the first TFTP.  I added the service module ip, ip unnumbered, loopback , and static route and that got rid of the error above, but I'm stuck again.
Please select from the following
1       Install software
2       Reload module
3       Disk cleanup
(Type '?' at any time for help)
Choice: 1
Package name: cue-vm-k9.uc500.8.0.6.pkg
Server url: ftp://192.168.1.21
Username: admin
Password:
Downloading ftp cue-vm-k9.uc500.8.0.6.pkg
Error: Download error
Can not download cue-vm-k9.uc500.8.0.6.pkg
error code 0 : error type 'couldn't connect to host'
Unable to install. Please try again
MOST IMPORTANT PIECES:
ip route 192.168.2.0 255.255.255.0 Integrated-Service-Engine0/0
interface Loopback0
ip address 192.168.2.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 192.168.2.1 255.255.255.0
service-module ip default-gateway 192.168.2.2
RUNNING CONFIG:
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname UC520
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
dot11 syslog
no ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 192.168.1.240 192.168.1.255
ip dhcp pool 192.168.1.0/24
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 208.67.222.222 208.67.220.220
   lease 3
no ip bootp server
ip domain name pop.local
ip name-server 208.67.222.222
ip name-server 208.67.220.220
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
ip tcp synwait-time 10
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
class class-default
  drop
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
class class-default
  drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface Loopback0
ip nat inside
interface Null0
no ip unreachables
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
zone-member security out-zone
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface FastEthernet0/1/0
switchport access vlan 10
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan10
description $FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source list 20 interface FastEthernet0/0 overload
logging esm config
access-list 1 remark HTTP Access-class list
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 deny   any
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 20 permit 192.168.2.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
no cdp run
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
banner motd ^CC
WARNING!  This computer system is private property and may be accessed only by
authorized users. Unauthorized use of this system is strictly prohibited and
may be subject to criminal prosecution.  The owners may monitor any activity or
communication on the system and retrieve any information stored within the
system.  By accessing and using this network, you are consenting to such
monitoring and information retrieval for law enforcement and other purposes.
Users should have no expectation of privacy as to any communication on or
information stored within the system, including information stored locally on
the hard drive or other media in use with this unit.
^C
line con 0
exec-timeout 180 0
logging synchronous
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input telnet ssh
scheduler allocate 4000 1000
scheduler interval 500
ntp update-calendar
ntp server 169.229.70.201 source FastEthernet0/0
ntp server 74.118.152.85 source FastEthernet0/0
ntp server 208.88.126.226 source FastEthernet0/0
ntp server 69.56.251.238 source FastEthernet0/0
end
thalfpop1
I changed the route from:
to:
! ip route 192.168.2.1 255.255.255.255 Integrated-Service-Engine0/0
and at least it connects now, but still no download
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> Connected, sending welcome message...
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> 220-FileZilla Server version 0.9.41 beta
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> 220 Please visit http://sourceforge.net/projects/filezilla/
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> USER
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> 331 Password required for admiral
(000004)4/7/2012 15:04:31 PM - (not logged in) (192.168.2.1)> PASS
(000004)4/7/2012 15:04:31 PM -  (192.168.2.1)> 230 Logged on
(000004)4/7/2012 15:04:31 PM -  (192.168.2.1)> PWD
(000004)4/7/2012 15:04:31 PM -  (192.168.2.1)> 257 "/" is current directory.
(000004)4/7/2012 15:04:31 PM -  (192.168.2.1)> EPSV
(000004)4/7/2012 15:04:31 PM -  (192.168.2.1)> 229 Entering Extended Passive Mode (|||51560|)
(000004)4/7/2012 15:05:01 PM -  (192.168.2.1)> PASV
(000004)4/7/2012 15:05:01 PM -  (192.168.2.1)> 227 Entering Passive Mode (192,168,1,21,201,105)
(000004)4/7/2012 15:05:01 PM -  (192.168.2.1)> disconnected.
Send the complete console log.
Recommend you remove all the inspect and policy commands because the only thing these is to break things and clutter config.
thalfpop1
Woohoo!  Thanks Paolo!  :-)  I was trying to take off different things and preserve the rest of it, but I should have just whiped all the security stuff and tried it.  Thanks so much for your help.  I got a little farther and now I'm really perplexed on this one.  The card I took out was only 1 GB I replaced it with a Sandisk 4GB and I got this output:
Bytes downloaded :  260761
Validating package signature ... done
- Parsing package manifest files... complete.
No installed manifests found.
- Checking Package dependencies... complete.
Downloading ftp cue-vm-langpack.uc500.8.0.6.pkg
Bytes downloaded :  1197193
Found Add-On Subsystem SID: e2e81cc6-39b5-47e1-9f83-b83c897fc50c Name: CUE Voicemail Language Support Version: 8.0.6
Found Add-On Subsystem SID: c28339fa-f7ae-4732-85ab-fa6c68b5de0c Name: CUE Voicemail Italian Version: 8.0.6
Found Add-On Subsystem SID: 49f09114-e0b0-4721-8b85-04be2064920c Name: CUE Voicemail European Spanish Version: 8.0.6
Found Add-On Subsystem SID: 27e5e2ab-1622-4c02-8a0a-cfad0d932148 Name: CUE Voicemail US English Version: 8.0.6
Found Add-On Subsystem SID: cf860289-67ac-4886-9295-a41e4c7a8487 Name: CUE Voicemail European French Version: 8.0.6
Found Add-On Subsystem SID: f0a41398-3917-4d49-b5ab-c2b39a80c121 Name: CUE Voicemail Latin American Spanish Version: 8.0.6
Found Add-On Subsystem SID: c4ca62e2-daff-40dc-b94e-bf20094bd700 Name: CUE Voicemail Mexican Spanish Version: 8.0.6
Found Add-On Subsystem SID: 88a84158-c090-4203-bde8-0d62eda200c7 Name: CUE Voicemail Arabic Version: 8.0.6
Found Add-On Subsystem SID: ab049397-cfad-4952-852a-8dfa69780cb8 Name: CUE Voicemail Dutch Version: 8.0.6
Found Add-On Subsystem SID: d60c3add-0c6b-4a99-8e5c-31019fe7939e Name: CUE Voicemail Swedish Version: 8.0.6
Found Add-On Subsystem SID: e1ed9919-31da-4c38-b029-9bbd8231d523 Name: CUE Voicemail Norwegian Version: 8.0.6
Found Add-On Subsystem SID: 683674a5-e6ef-4c97-8e05-efbba1e6fe47 Name: CUE Voicemail Canadian French Version: 8.0.6
Found Add-On Subsystem SID: c3d2409a-ae9a-47d3-baf0-3c1a3ff85d82 Name: CUE Voicemail Portuguese Version: 8.0.6
Found Add-On Subsystem SID: b18bcd35-5a37-46af-b230-0d9c27713dec Name: CUE Voicemail Turkish Version: 8.0.6
Found Add-On Subsystem SID: 3e72a8ae-45d2-4790-b0b5-9301600e886e Name: CUE Voicemail Hungarian Version: 8.0.6
Found Add-On Subsystem SID: fa803d25-9c89-4171-a14c-ec12d6ed6b8c Name: CUE Voicemail UK English Version: 8.0.6
Found Add-On Subsystem SID: 3f968fd0-6598-48e2-be1c-4af6c2e02e02 Name: CUE Voicemail German Version: 8.0.6
Found Add-On Subsystem SID: 88f73a6c-884d-4838-b162-1b544dd6583f Name: CUE Voicemail Danish Version: 8.0.6
Found Add-On Subsystem SID: a2ba4f96-3452-40c3-83ad-c442cb6bf42f Name: CUE Voicemail Brazilian Portuguese Version: 8.0.6
Found Add-On Subsystem SID: ea206a88-e44f-488b-a660-114a3b179065 Name: CUE Voicemail Korean Version: 8.0.6
Found Add-On Subsystem SID: 372fa3fd-1efb-4353-9005-45876646a351 Name: CUE Voicemail Mandarin Chinese Version: 8.0.6
Found Add-On Subsystem SID: 6cdfed34-6d45-48fd-afe0-717e589c9aa9 Name: CUE Voicemail Japanese Version: 8.0.6
Found Add-On Subsystem SID: 24cb0b00-ed1c-4463-bf6f-261b15dfb3e7 Name: CUE Voicemail Russian Version: 8.0.6
- Checking Manifest dependencies for subsystems in the install candidate list...
complete
WARNING:: Software installation will clear disk contents
Continue [n]? yes
cleaning fs
prepfs.sh: freddo reiser /mnt clean
hd_name: /dev/hda
hd_part: /dev/hda1
partition_disk: /mnt clean /dev/hda1
umount: /dev/hda1: not mounted
check_partition_count: 1
Not enough disk space to download necessary files.
Error encountered while downloading payload(s)
Hi Tyler,
side.
That is what I meant to say..
+5 to David for providing the specific information!
Was just clearing it up :-)
Cheers,
David.
David,
It appears that we have at least one customer that might need to have the CUE flash replaced in their UC520. I am trying to find the correct replacement CompactFlash card for the CUE module on the UC520. I did a web search, and came across a Transcend 2GB 133x CompactFlash memory card. Will the Transcend 2GB 133x CompactFlash memory card work with the CUE module on the UC520?
How do I replace the CUE CompactFlash card on the UC520?
John Platts
Hi John,
You always ask me the hard questions LOL
Ok the 133X Card is untested by me so I cannot give you an assurance it will work as you would expect it too The Linux kernel on the CUE may not support UDMA mode or we don't have the ability to turn it on (???) and 133X Cards require it from memory, they might be backwards compatible but not sure if the CUE-OS supports this speed card (Maybe recognition of it might be a problem??).
2GB Is the right size though the latest CUE should support that as the Kernel was also updated I believe with the latest SWP, I guess my advice is try and and test it and see if it works the worst that can happen is that it doesn't work
How to replace it? Well open the UC-520 up and you will see a Compact Flash Card slotted in, I think it is on the right hand side... Or was that the 2800 series Its been like 2 years since I did my last one Anyway you take out the old one and replace it with the new one... If the old card can still be read in a computer I would suggest you try and copy over the entire contents of it to the new card this may prevent loss of data.
Once the new card is in you will need to upload the entire CUE OS to the new card via CLI, this process is a little long but should be quite painless, I don't have the PDF/Document I created on doing this with me as I am at work right now, but If I find it at home I will post it up for you
Cheers,
David.
[DISCLAIMER] In all cases genuine Cisco products should be first prefence and is the recommended solution when replacing faulty items, using a third-party product will in any event place the unit out of warranty, and so will opening the system up to do the replacement without express authority by Cisco to do so....
Sorry had to say that so I dont get a scolding for promoting DIY repairs
I have the same problem on my uc540. "Unable to read /dev/hda". I have tried formatting the card in windows using a card reader. But it just does not seem to find the /dev/ folders.
What are the steps needed to restore the system structure?
