01-15-2010 06:48 PM - edited 03-21-2019 02:02 AM
When connected with the Cisco Anyconnect client the IP Communicator will start and register with system correctly. However, I'm not able to make calls with it (don’t get a dial tone) and every 3 minutes or so all the softkeys will disappear and then it will say registering and the softkeys will reload. However, still cannot make a call.
The IP Communicator will work fine on the same computer using the IPSEC vpn client.
Any ideas?
01-19-2010 08:14 AM
What version of IOS are you running? What version of IP Communicator are you running? This might be a bug with the SSL VPN, but hard to know without version information.
02-15-2010 07:22 PM
IOS version: Version 12.4(22)YB4
IP Communicator version 7.0.3.0 running on XP SP3 Pro.
Let me know if you need additional information.
Thanks for your help!
02-16-2010 07:57 AM
What version of anyconnect are you using?
02-16-2010 06:53 PM
AnyConnect Version 2.3.2016. I have not upgraded to the latest version because I'm using a self signed cert for testing which I believe will cause problems with the newer version?
All the other programs I've tested work fine over the AnyConnect client (Exchange, RDP, internal websites, file shares, etc).
Jeremy
02-17-2010 09:46 AM
Would you mind opening a case for this? I am familiar with one bug on this, but it is fixed on your release (CSCsv64889).
This is probably going to be a bit to difficult to do over the community.
