Hi Everyone,Can anyone show me or give me a link on where i can find a document with all commands prompts for the UC520 that I can print or download. Thank you
I have a IP Phone on my desk which I use as a primary. If I sit at another employees desk temporarily, how do I log into her phone to receive calls made to my extension?Do I need to turn this feature on in the UC-540 first?Phones are 7975G and 7925 c...
Caller gets a fax tone but always errors out. I was originally trying x801 but had the same problem. Changed to x291 - no differenceI have followed the 7.37 onramp document that Marcos had referenced in posting pretty much exactly. I am using CCA 2.2...
Hi everyone,I've downloaded and installed the Cisco Call Connector for dynamics CRM, I've installed on a test machine and everything was installed correctly.Although now on the live server, the server installation says you need to manually enable the...
My customer will have:ISP 1 for data (30MB) vlan 1 (carrier provided a Cisco 800 and public IP) up and runningISP 2 for Voice (SIP) vlan 100.I am looking for the data configuration on FA0/1/0 to send my data traffic to ISP 1 cisco 800.The WAN port wi...
Hi!,I´m configuring provisioning files for my new SPA-525G. I´ve configured "Protect_IVR_FactoryReset" and I would like to Password Protect some other options. I don´t want to use Admin Password, because it protects all options in the phone menu. Do...
I am using SPA9000 with SPA400 and SPA9** . 2 PSTN lines connected on Line 1 and 2, after configuring SPA9000 and SPA400, I have routed line1 to Ext:111 and line2 to Ext:107. when i try to dial these 2 PSTN lines from outside, it rings on Line2, Ext:...
Hi,fairly new to the SPA9000 and probably asking something obvious but if you had two SPA9000s on a reasonably fast WAN can they communicate / route calls directly? Site-to-site routing in place for IP traffic. Also, is there an easy way to do call a...
I have a UC-540 with an active Cisco XP support agreement.Where can I go (URL please) to download a software based phone (softphone)?Do I need to purchase a license for IP COMMUNICATOR & LIC FOR CALLMANAGER (CISCO Part# L-SW-IPCOMM-E1-CH1) ?Will the ...
would like to know if there’s a way to restrict Linksys ATAs(mainly SPA2102/3102-R) and IP Phones(SPA 9x2/500series) to only accept SIP invites from the IP they register to? Can’t seem to find a parameter that would suggest it can, so it’s either it ...
I have a simple setup. 2 x FXO lines. 2 x 502 phones. I setup a call blast group (pilot #501) to ring both phones for 10 seconds then forward to extension 201's voicemail. Both phones ring no problem for 10 seconds but then the call disappears. ...
We are setting up a project to consolidate 7 locations to a colocation site.We need a firewall at each of the 7 remote sites for around 10-20 at each site.Then we need one at the colocation for approx. 70 users...we were thinking of the ASA 5510.In t...
We're using CCA 2.1(1) and software pack 7.1.3. I spelled someone's name wrong when creating it, and they've already gone on to create voicemail, passwords, call prompts, etc. It shows up wrong in the directory, on the label, in CUE web admin, etc.Un...
Our UC 520 lost power. When power was restored, we were unable to connect to it. Our phones and internet are down. Does anyone know of a way to restart a UC 520 successfully?
I am using SPA9000, SPA400 and IP phones SPA942. when we dial the extension, it waits for 3 to 5 sec before ringing. I want to dial the extension and it should ring immediately without pressing dial or # buttons. can someone solve this issue please.
