UC520 mailbox removal
occaustin11
   First of all, I am a newbie on this, so any patience would be appreciated. We are trying to remove a user exension and add a new user under the same extension. When I removed the user in CCA under Telephony->Users and Extensions->Users and Phones, then added the new user, i get a  "dailed to create personal mailbox on extension 108, there is a personal mailbox on this extension with user *username*" error, with the old username there. I then went into the voicemail settings under the mailbox tab and found the user mailbox is still there, but there is no "remove" option.
What do i do here. Try googling "UC520 remove mailbox" and you get instructions on how to add and edit, no removal instructions. HELP!!!!
Hello Ted,
If you go to WEB GUI of the CUE(voicemail) by default it is 10.1.10.1 you can check yours under the integrated service engine in the running config.
Then under Voicemail->Mailboxes you may select the mailbox and delete it there is an option.
HTH,
Alex
*Please rate helpful posts
Hello Ted,
HTH,
Alex
I knew it was something simple like that. Thanks.
