08-19-2013 04:41 PM - edited 03-21-2019 07:40 AM
hi,
I've configured my 520 using cca.
under telephony, ports and trunks, sip trunk I've configured the voip.ms trunk.
I can place outgoing calls but when I dial my xxx xxx xxxx number from any land phone I get a busy signal.
now under dial plan - incoming, under the direct dialing tab I've configured it using my did.
lets assume my did is 1234567890
so when I call that number using a land phone I get a busy signal. again I can place many outbound calls at the same time and it works.
maybe this can help... I did a debug voip dialpeer
when I call my did this is what I get but then on my landphone I hear a busy signal.
I'VE MASKED MY REAL DID WITH 1234567890
013685: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=1234567890, Called Number=1234567890, Peer Info Type=DIALPEER_INFO_SPEECH
013686: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=1234567890
013687: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=1234567890, Expanded String=1234567890, Calling Number=1234567890T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
013688: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20010 Is Matched
013689: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20015 Is Matched
013690: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
013691: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=1234567890, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
013692: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20010
2: Dial-peer Tag=20015
I'm doing all this using CCA, I'm running the latest version of everything.
thanks.
08-19-2013 05:20 PM
Please setup the following debug, test again, and post the debug output here
debug ccsip messages
-john
08-19-2013 06:28 PM
I changed my landline to 0987654321
and the did to 1234567890
50.x.x.x that's my internet ip.
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
Via: SIP/2.0/UDP 67.205.74.184:5060;branch=z9hG4bK03406df5;rport
To: <1234567890>;tag=6DC0780-1944
Date: Tue, 20 Aug 2013 01:08:24 GMT
Call-ID: 05acb4d37a11d2cf2cd4774e4717f4b1@67.205.74.184:5060
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 01234567890>0987654321>
013730: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1234567890@50.101.184.208 SIP/2.0
Max-Forwards: 70
Contact: <0987654321>
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 00987654321>1234567890>0987654321>
013731: //1421/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:montreal.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.14:5060;branch=z9hG4bK783183D
To:
Date: Tue, 20 Aug 2013 01:08:37 GMT
Call-ID: E06C38AB-86B11E3-8468F06D-39B2023F@voip.ms
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <192.168.2.14:5060>
Content-Length: 0192.168.2.14:5060>
013732: //1421/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.14:5060;branch=z9hG4bK783183D;received=50.101.184.208;rport=55833
To:
CSeq: 101 OPTIONS
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Contact: <67.205.74.184:5060>
Accept: application/sdp
Content-Length: 067.205.74.184:5060>
08-19-2013 06:31 PM
I don't see the initial invite from Voip.MS but it looks like an issue with how their invite is configured.
Can you post the invite?
-john
08-19-2013 06:45 PM
actually I'm getting a fast busy when I call my number.
Received:
INVITE sip:1234567890@50.101.184.208 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.184:5060;branch=z9hG4bK27096a8f;rport
Max-Forwards: 70
To: <1234567890>
Call-ID: 63f709f02aef8bad3ab9834b251eba7a@67.205.74.184:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 20 Aug 2013 01:43:30 GMT
Remote-Party-ID: "AMIRIAN P ." <0987654321>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 2950987654321>0987654321>1234567890>0987654321>
v=0
o=root 64234287 64234287 IN IP4 67.205.74.184
s=voip.ms
c=IN IP4 67.205.74.184
t=0 0
m=audio 19130 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
013817: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <1234567890>;tag=6FC2948-DB
CSeq: 102 INVITE
013818: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 ACK
User-Agent: voip.ms
08-19-2013 06:57 PM
Is the UC connected to the internet directly with the IP 50.101.184.208 or is there another router/firewall in front of the UC?
-john
08-19-2013 07:01 PM
there is the isp device. some sort of a 'linksys' type device... you think that's causing the issue?
08-19-2013 07:05 PM
Yes, that is exactly the problem. Since the invite comes to the host IP, the UC rejects the calls as it doesn't have that IP, thus it thinks the call is not actually for it. If the Linksys router has a SIP ALG feature, you will want to enable that, as it will fix the SIP SDP messages. Another option, is to put that IP on the UC under a loopback interface.
I found this forum post which details your exact issue, and has some solutions for that customer: https://supportforums.cisco.com/thread/2058340
Hope this helps.
-john
08-20-2013 01:56 PM
hah that loopback thing actually works.
my only issue is now that my isp gives me a dhcp
thanks John!!
