12-17-2012 03:14 AM - edited 03-21-2019 06:45 AM
Hi guys,
which is the best way to upgrade a UC520 (CME: 7.0 CUE: 7.0.3) to software pack 8.6.1 (CME: 8.6 CUE: 8.6.5)?
first upgrade the CUE and then the CME?
Thanks.
Cristian
Solved! Go to Solution.
12-17-2012 04:57 AM
If you want to use CCA, follow CCA directions.
If you want to use CLI, it makes no difference.
12-17-2012 04:57 AM
