09-05-2011 05:23 AM - edited 03-21-2019 04:36 AM
I have a SBS2003 server who is the DHCP server (192.168.1.1) and I want to install the UC520 in this network.
Please give me the best practice!
BR
09-06-2011 05:55 AM
I need an urgent help! Thx
As I said the UC520 in a normal configuration is the DHCP server and the SBS2003 also, so, there is a problem.
I can't change the IP adress of the SBS2003 who is the 192.168.1.1
As I understand, I have to desactivate the DHCP on the UC520 and change the address range to [192.168.1.1;192.168.1.256], is it true?
If it's ok! I've got a problem, I have to change the adress of the UC520 from 192.168.1.1 to 192.168.1.2! Can you confirm it and give me the best method?
Many thx.
BR
09-06-2011 07:47 AM
Search next time
https://supportforums.cisco.com/message/3430838
I also don't use the DHCP functionality on the UC, just change the default IP address and remove the DHCP server after applying the configuration.
Don't forget to save settings!
Good Luck
09-06-2011 08:05 AM
Thanx for the link!
I'll search next time!
I'll test it and be back to give my feed back
BR
09-07-2011 04:08 AM
I finished the installation and it works!
BR
