UC520 with SR520s - EZ VPN - 1 way Audio
Joseph Chambers
I have customer where all of the phones are attached to SR520s at their homes & connect via EZ VPN.
Randomly, they had 1 way audio issues due to EZ VPN and how they were natd by the EZ VPN.
I had to enable the phones to use the UC520 to be a media termination point:
ephone  1
mtp
reset
5 Replies 5
Tomoo Esaka
For the teleworker sites, did you have split tunneling enabled or was it in full tunnel mode? A screenshot of the EZ-VPN server config on UC520 or whichever device you select as the head-end EZ-VPN server would tell us this.
Can you send the CCA troubleshooting log for both SR520 at remote site and UC520 and head-end?
You can collect this information by using Help > Support Information > Troubleshooting log in CCA. You can unicast this info to tesaka@cisco.com if you prefer.
Rgds,
Tomoo
Under troubleshooting, telephony diagnostics, get popup errors when trying to debug phone & voice debugs.
Says file can't be created
Can you look to see if it is created on the desktop?  I have had this problem, but the file was actually created.
It created in the location I specified...even though it said it didn't.
