07-26-2018 05:09 AM
Hello all,
Use here at home a Cisco UC520W with CME 8.6, and try to config a speed dial button on the two 7931 phones. Have two questions:
1. How can config a speed dial button on 8.6 with 7931 phones?
2. How can find the "User option web page"?
Greetings
Marco
Solved! Go to Solution.
08-29-2018 08:25 AM
You can configure the speed dials with CCA is real simple.
Configure
Telephony
Users and extensions
Users and phones
Select the profile you want to modify ( add speed dial button)
Speed dial tab and then assign ext you want there or the phone.
08-29-2018 08:25 AM
08-31-2018 03:58 AM
