07-12-2013 07:26 AM - modifié 03-21-2019 07:33 AM
Are the spa232d usable with UC540? Not only throuth the analog interface but throuth voip interface?
le 07-12-2013 09:09 AM
Hi albenora72,
Yes the spa232d can be used through the analog interface and also the voip interface. But it is not supported by the CCA.
Naresh Arjunan
le 07-16-2013 05:51 AM
thanks for the answer.
it should be possible to have an example of the configuration throuth the voip interface?
because i jast have configured the SPA232D throuth the analog interface but i would like to use or better to see the two possible configurations.
i think i should create a sip trunk between the UC540 and the SPA232d or i have to do something else?
could you help me?
tnx
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
