07-12-2013 07:26 AM - edited 03-21-2019 07:33 AM
Are the spa232d usable with UC540? Not only throuth the analog interface but throuth voip interface?
07-12-2013 09:09 AM
Hi albenora72,
Yes the spa232d can be used through the analog interface and also the voip interface. But it is not supported by the CCA.
Naresh Arjunan
07-16-2013 05:51 AM
thanks for the answer.
it should be possible to have an example of the configuration throuth the voip interface?
because i jast have configured the SPA232D throuth the analog interface but i would like to use or better to see the two possible configurations.
i think i should create a sip trunk between the UC540 and the SPA232d or i have to do something else?
could you help me?
tnx
