UC540/BRI interface in Dubai
steenbroberg
Hi Community
Do anyone have experience with using UC540W-BRI-K9 in Dubai. Can there be some problem about there ISDN protocol compared to europe???
Alberto Montilla
Dear Sir;
I have not set it up myself, but I have found that configuration uses DSS1 (EuroISDN). Set it to TE mode. Not sure if PTP or PTMP setup though.
Alberto
David Trad
Hi Steen,
The UC-500 series with BRI works in the UAE on their ISDN standard, you can also for it to be setup as Permanent Layer-1 Active and also PTMP, it is better to make sure that the layer-1 is always active and not on a demand basis.
Etisalat can support BRI maybe ask them to set it up as ETSI standards if you can...
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
