UC540 License Question
rsalinasa
Hello, I want to know if the UC540 comes with 24 licenses (permanent) or If I Upgrade to Software Pack 8.2 the 24 licenses would be permanent, or the number increase?
Darren DeCroock
Level 4
Level 4
Hello Roberto,
The UC540 loaded with Software Pack 8.2 (IOS 15.1(2)T4) will come with 24 permanent licenses.  Any UC540 loaded with a older Software Pack, will come with 8 permanent licenses.  If that unit is running an older Software Pack, and you then upgrade to 8.2, it will be automatically upgraded to 24 permanent licenses.
Hope that was understandable..
Thank you,
Darren
Darren DeCroock
Level 4
Level 4
Hello Roberto,
Thank you,
Darren
Ok, yes I understand Darren
Thanks For The Answer
Cheers
