UC540 multiSite and transcoding
John Martin
Hi everybody,
I have a multisite configuration with two UC540. All works fine but there is something that it isn't work properly.
Scenario:    SIte A (81...)<-------------------------------------------> Site B (82...)
Calls between sites, no issue.
Call to a blast group from internal phone, no issue.
Call from SIP Trunk to a differents phones ( site A and B telephones ) ..... don't work properly. The Sip trunk is configurate in site B.
When a incoming call is in progress, phones in the site A and B ring. If somebody pick up the call from Site A, works fine. If somebody pick up the call from Site B, no audio.
I assume that is a issue with the codecs but I'm not sure how to fix it.
Any advice ?
John Martin
More info....
UC540_FACT# show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x6 11F5 0x88FC6030 50/0/9.0 ABC g711ulaw 20001/5
0x7 11F5 0x885BA478 0/4/0 0/1:1 *ABC g711ulaw 5/20001
0x13C9 24C7 0x897A52D4 50/0/272.0 *250 None 3005/20011
2 active calls found
This is the voice call status while the call is active. Here , I make mayself one question.
1.- Why the call hasn't codec ? The extension 250 is a share extension.
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
21474- voip up up 511 0 syst loopback:rtp
83647
21474- voip up up 512 0 syst loopback:rtp
83646
21474- voip up up 513 0 syst loopback:rtp
83645
21474- voip up up 514 0 syst loopback:rtp
83644
21474- voip up up 516 0 syst loopback:rtp
83643
21474- voip up up 518 0 syst loopback:rtp
83642
21474- voip up up 519 0 syst loopback:rtp
83641
21474- voip up up 520 0 syst loopback:rtp
83640
1 pots up up 0 down 0/0/0
2 pots up up 402 0 up 0/0/1
3 pots up up 403 0 up 0/0/2
4 pots up up 404 0 up 0/0/3
5 pots up up ABC 0 up 0/4/0
6 pots up up 0 down
50 pots up up 0 down 0/1/0
51 pots up up 0 down 0/1/1
52 pots up up 0 down 0/1/2
53 pots up up 0 down 0/1/3
54 pots up up A0 0 up 0/1/0
55 pots up up A1 0 up 0/1/1
56 pots up up A2 0 up 0/1/2
57 pots up up A3 0 up 0/1/3
2000 voip up up 399 0 syst ipv4:10.1.10.1
2100 voip up up 0 syst
2101 voip up up 81... 0 syst ipv4:192.168.10.1
66 pots up up 9[0-1,6-9]T 5 up trunkgroup ALL_FXO
2001 voip up up 299 0 syst ipv4:10.1.10.1
1000 voip up up 0 syst sip-server
1001 voip up up *.. 0 syst sip-server
1003 voip up up 0 syst ipv4:10.1.10.1
1005 voip up up 0 syst ipv4:10.1.10.1
1009 voip up up 0 syst ipv4:10.1.10.1
1020 voip up up 7[0-1,6-9]T 1 syst sip-server
20001 pots up up BCD$ 0 50/0/9
20002 pots up up 226$ 0 50/0/263
20003 pots up up 224$ 0 50/0/264
20004 pots up up 223$ 0 50/0/265
20005 pots up up 222$ 0 50/0/266
20006 pots up up 280$ 0 50/0/267
20007 pots up up 219$ 0 50/0/268
20008 pots up up 430$ 0 50/0/269
20009 pots up up 251$ 0 50/0/270
20010 pots up up 252$ 0 50/0/271
20011 pots up up 250$ 0 50/0/272
20012 pots up up 218$ 0 50/0/273
20013 pots up up 421$ 0 50/0/274
20014 pots up up 422$ 0 50/0/275
20015 pots up up 217$ 0 50/0/276
20016 pots up up 401$ 0 50/0/277
20017 pots up up 214$ 0 50/0/278
20018 pots up up 215$ 0 50/0/279
20019 pots up up 216$ 0 50/0/280
20020 pots up up 207$ 0 50/0/281
20021 pots up up 290$ 0 50/0/282
20022 pots up up 291$ 0 50/0/283
20023 pots up up 213$ 0 50/0/284
20024 pots up up 206$ 0 50/0/285
20025 pots up up 204$ 0 50/0/286
20026 pots up up 208$ 0 50/0/287
20027 pots up up 211$ 0 50/0/288
20028 pots up up 212$ 0 50/0/289
20029 pots up up 210$ 0 50/0/290
20030 pots up up 220$ 0 50/0/291
20031 pots up up 209$ 0 50/0/292
20032 pots up up 221$ 0 50/0/293
20033 pots up up 205$ 0 50/0/294
20034 pots up up 203$ 0 50/0/295
20035 pots up up 202$ 0 50/0/296
20036 pots up up 201$ 0 50/0/297
20037 pots up up 6... 0 50/0/298
20038 pots up up A801... 0 50/0/299
20039 pots up up A800... 0 50/0/300
40002 voip up up 225 0 syst ipv4:192.168.100.10:
3005 voip up up 0 syst sip-server
This is a mess !!!!
