07-15-2015 05:48 PM - edited 03-21-2019 08:43 AM
I had a power outage and had to reconfigure my UC540.
I was able to successfully download the CCA and reconfigure my device but am unable to patch it because I do not have the latest software pack. Does anyone have access to the latest Software Packs for the UC540 so that I may update my UC540 back to its latest update?
I receive an error everytime i try to download something. I just want to patch my expensive working UC540.
https://supportforums.cisco.com/document/36746/uc-500-software-packs/
Solved! Go to Solution.
07-22-2015 05:55 PM
Hey Kai,
Thanks for the update, If you can provide me the serial number and a CCO ID, I can proceed and open a case and can work with you regarding this.
Akshay
02-24-2016 03:12 PM
07-20-2015 11:34 PM
Hey Kay,
For downloading the software, you'll have to contact your accounts team and they can enable access to download the software from cisco.com to your CCO ID. After that if still you're unable to download then you'll have to open a Cisco TAC case to resolve this.
Akshay
07-22-2015 04:04 PM
Askshay,
This is a small business unit 8 people. We don't have an "accounts team". Every time i attempt to call Cisco Customer support, I get put on hold until the call is dropped.
My UC540 is working, however I would like to patch it to the latest release. I use to have a copy of the software but am now in need of it again.
07-22-2015 05:55 PM
Hey Kai,
Akshay
02-24-2016 03:12 PM
03-03-2016 12:47 PM
Roger
