04-02-2014 10:31 PM - edited 03-21-2019 08:11 AM
I have installed a VWIC2-2MFT-T1 card into UC540. And I configured everything using CCA. I can see the new E1/T1 tab in CCA Telephony -> Ports and Trunks ->PSTN trunk setting.
I configured it as E1
Channel Signaling: ISDN PRI
Switch type: Primary NET5
Bear capability: Speech
Time slot: 1-31
Then, I connected the crossover E1 cable to the port, the other side is to our carrier's port directly. The port AL alarm is solid yellow/amber.
I am using lastest CCA 3.2.3
firmware 8.6.2.
show controllers e1 says the E1 is still down?
E1 0/2/0 is down.
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (94 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 94 Unavail Secs
Total Data (last 4 15 minute intervals):
102 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 3600 Unavail Secs
I noticed the loss of signal error and tried all the possible cables. I am sure I am using the correct one. (pin 1,2,4,5, reverted at other side, and I used the same cable to connect from the carrier to our another sangoma E1 gateway, it works)
UC_540#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/2/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
show diag result
HWIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : C0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC13471RPT
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
Is the card broken? how can I check that?
Could someone please help? Thanks in advance.
PS: I am in Australia and I am sure the port is not in administrative shutdown.
Solved! Go to Solution.
04-03-2014 11:46 AM
Check the framing. Now is CRC4. Try "framing no-crc4".
Try a straight cable 1,2,4,5.
Test the controller e1 whit "loopback" command.
Regards.
04-03-2014 11:46 AM
Regards.
