06-10-2011 06:32 AM - edited 03-21-2019 04:12 AM
Hi i wanto to know the C210m2 server capacity for ip phones, ccx agents, etc. running on BE6000.
I found documentation about C200 on BE6000. not c210.
For UCS C200, you must align with these rules:
Regards.
Carlos
Solved! Go to Solution.
06-10-2011 02:17 PM
The only deployment model for the BE6000 is on a C200. The only reason you would order a BE6k is because you're looking for the bundle discount of licensing plus hardware. If you want a C210 you need to order UCL or UWL licensing normally.
A C210 M2 is - generally speaking - equivelent to four MCS7845 servers from an overlay perspective. The specific interactions of each application may allow for fewer or more VMs to exist. It takes a bit of reading but it's on the Wiki: http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
06-10-2011 02:17 PM
06-13-2011 01:01 PM
Thanks Jonathan.
Regards.
