01-14-2010 02:02 PM - edited 03-21-2019 02:01 AM
I don't suppose you can help me out with UK PRI (ISDN30) settings?
I've set it as an E1 ISDN30 Primary NET5. There is then an option for Bearer Capability that I can't find a standard setting for.
CD light comes on next to the PRI port, but incoming calls get a BT The number you have dialled is tempoararily unavailable message.
Any hints grately received.
Adam
01-14-2010 03:13 PM
http://www.cisco.com/en/US/docs/ios/12_2/dial/configuration/guide/dafchant.html#wp1000940
Not a bad guide. Have you tried isdn incoming-voice voice command?
01-19-2010 06:04 AM
I've gone through this guide.
I'm getting this in a debug isdn q921:
004193: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
004194: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004195: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
004196: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004197: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
004198: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004199: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
004200: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004201: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
004202: ISDN Se0/3/0:15 Q921: L2_EstablishDataLink: sending SABME
004203: ISDN Se0/3/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
004204: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004205: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
004206: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004207: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
004208: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E21EF)
004209: ISDN Se0/3/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
(and loads more)
and show isdn status shows:
Global ISDN Switchtype = primary-net5
ISDN Serial0/3/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 48
--More--
I'm finding contradictary advice as to whether TEI_ASSIGNED is good or bad. Any advice?
Adam
01-19-2010 11:27 AM
Try this under the Serial Interface (D channel):
isdn protocol emulate network Marcos
02-02-2010 03:08 AM
I think I may have identified an incompatability with the ISDN 30 line and the cisco kit, so I'll ask the question in a different way:
Is the UC520 compatible with a DASS signalled ISDN 30 line (i.e. not ETSI ISDN30e)?
Looks like I'll have to have the line converted, but if you can give me a yes/no answer it would help.
Adam
04-12-2010 07:06 AM
UC500 are not compatible with DASS. Need to get ISDN upgraded to ISDN30e. Had the exact same problem. Will be chargable from BT at £10 a channel (capped at £600). Make sure your telco doesnt rip you off ;)
