10-06-2011 07:04 AM - edited 03-21-2019 04:46 AM
Hello, I have a client that says when they press the "Conference" button on their 7945 phone it says they are unable to conference.
Any ideas why this is happening? What should be checked.
The system is a UC520 with five 7945 phones.
Thank you, Paul
Solved! Go to Solution.
10-06-2011 12:59 PM
Paul,
As I was looking at the config, I checked the conferencing and see this:
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile- Using codec711
codec g711ulaw
codec g711alaw
maximum sessions 4
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
associate application SCCP
shutdown
Seems that conferencing is not enable or somehow go shut down. If you are using CCA, I would go in and disable conferencing, then re-enable it again. If using CLI, I would just go into "dspfarm profile 1 conference" and do a "no shut".
Thank you,
Darren
10-06-2011 12:22 PM
Hello Paul,
Hard to say exactly without seeing the config, but my guess would be that conferencing in CCA is not enabled. That is the first thing I would check.
Thank you,
Darren
10-06-2011 12:53 PM
Darren, here is the Running Config:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.04.15 14:54:34 =~=~=~=~=~=~=~=~=~=~=~=
term len 0
UC520#sh run
Building configuration...
Current configuration : 60593 bytes
! Last configuration change at 14:46:03 EDT Fri Apr 15 2011 by admin
! NVRAM config last updated at 12:42:19 EDT Fri Apr 15 2011 by admin
version 15.0
parser config cache interface
no service pad
no service timestamps debug uptime
service password-encryption
service internal
service compress-config
hostname CVMS-UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.150-1.XA3a
boot-end-marker
logging buffered 1000000
no logging rate-limit
enable secret.
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone EDT -5
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-2162315577
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2162315577
revocation-check none
rsakeypair TP-self-signed-2162315577
crypto pki certificate chain TP-self-signed-2162315577
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32313632 33313535 3737301E 170D3131 30333138 31353238
32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31363233
31353537 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100F166 A5E1149C A31F308F F8719BED 2043C8B6 CF5A5124 953D90F4 C671168D
F725E71C 10522D27 96593C4B 3FD739E9 EE8A2887 D40CE38C 4B77FC09 366C0A9B
E280C202 1DDBCA14 AEDBE906 61F97B32 BFFFBA29 6AFDC32C 579A5AFB 4CCF06D4
34DD11EF D012B277 9E3BC1EA 0CC8FAF0 310953E4 29DB0F86 C6F3AF22 66396762
25B30203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 1743564D 532D5543 3532302E 62726F61 64766F78 2E6E6574
301F0603 551D2304 18301680 14D746CE 14B75A7D A2409E48 F517F8A2 3BDC4320
14301D06 03551D0E 04160414 D746CE14 B75A7DA2 409E48F5 17F8A23B DC432014
300D0609 2A864886 F70D0101 04050003 81810003 A0C8942C 0EA56E37 DA01FFAF
76EE63B7 932B2DD5 6C3CEB83 31437061 46F2500E B1994DD6 82976333 DB1F797C
474C02CC 715FC9F3 4B4A3264 19AD2D5E 2584C5F0 8C9F11B1 653CF85D 2E182CBB
60D88BD7 65198714 5DEBD481 71466495 420B8CD9 FDC9EC7B 6D422E1B FDEA10B7
1513B070 5E3C3D9E 3DAF2708 485F56FF BC411D
quit
dot11 syslog
dot11 ssid CVMS-Wireless
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 106D3F343600020A5E
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 99.187.94.198 68.94.156.1
ip domain name broadvox.net
ip name-server 4.2.2.1
ip inspect log drop-pkt
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic timeout 300
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
port 0/0/0
fallback-dn 107
port 0/0/1
fallback-dn 109
port 0/0/2
fallback-dn 108
parameter-map type inspect global
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 3600
localhost dns:BroadVox.net
outbound-proxy dns:nd01-03.fs.broadvox.net
no update-callerid
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g729br8
voice class custom-cptone CCAleavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice register global
max-dn 56
max-pool 14
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 4
rule 1 /2167650358/ /111/
voice translation-rule 6
rule 1 /216xxxxxxx/ /105/
voice translation-rule 7
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /216xxxxxxx/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /^...$/ /2167650358/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^\(.*\)/ /9\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1113
voice translation-profile CVMS_Main-OP_Called_4
translate called 4
voice translation-profile CVMS_Three-OP_Called_6
translate called 6
voice translation-profile CVMS_Two-OP_Called_7
translate called 7
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
license udi pid UC520W-8U-4FXO-K9 sn FHK1xxxxxxx
archive
log config
logging enable
logging size 600
hidekeys
username Admin privilege 15 secret
process-max-time 50
ip tftp source-interface Loopback0
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-all SIP
match protocol sip
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
class-map match-all RTP
match protocol rtp
class-map match-any Voice
match dscp ef
match access-group 10
match protocol rtp
policy-map Voice-out
class Voice
priority percent 99
set dscp ef
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key CVMSvpn1
dns 68.94.156.1 99.187.94.198
pool SDM_POOL_1
max-users 10
crypto isakmp profile sdm-ike-profile-1
match identity group EZVPN_GROUP_1
client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
client configuration address respond
virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id FastEthernet0/0
ip access-group 105 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
service-policy output Voice-out
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
interface FastEthernet0/1/1
spanning-tree portfast
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid CVMS-Wireless
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
interface Virtual-Template3 type tunnel
ip unnumbered BVI1
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
bridge-group 100 spanning-disabled
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 103 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 104 in
ip nat inside
ip local pool SDM_POOL_1 192.168.20.10 192.168.20.20
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.1.1.1 80 interface FastEthernet0/0 5060
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.10.1
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 3 permit 208.93.224.230
access-list 3 permit 208.93.224.224
access-list 3 permit 208.93.226.214
access-list 3 permit 208.93.227.208
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 208.93.226.208
access-list 3 deny any
access-list 10 permit 208.93.226.5
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 101 permit udp any host 10.1.10.2 eq isakmp
access-list 101 permit esp any host 10.1.10.2
access-list 101 permit ahp any host 10.1.10.2
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip 192.168.10.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 192.168.10.1 eq non500-isakmp
access-list 103 permit udp any host 192.168.10.1 eq isakmp
access-list 103 permit esp any host 192.168.10.1
access-list 103 permit ahp any host 192.168.10.1
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 10.1.1.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 104 permit udp any host 10.1.1.1 eq isakmp
access-list 104 permit esp any host 10.1.1.1
access-list 104 permit ahp any host 10.1.1.1
access-list 104 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 104 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 192.168.10.0 0.0.0.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark auto generated by SDM firewall configuration##NO_ACES_32##
access-list 105 remark SDM_ACL Category=1
access-list 105 permit tcp any any eq 5060 log
access-list 105 permit udp any any eq non500-isakmp
access-list 105 permit udp any any eq isakmp
access-list 105 permit esp any any
access-list 105 permit ahp any any
access-list 105 deny ip 10.1.10.0 0.0.0.3 any
access-list 105 deny ip 10.1.1.0 0.0.0.255 any
access-list 105 deny ip 192.168.10.0 0.0.0.255 any
access-list 105 permit udp any eq bootps any eq bootpc
access-list 105 permit udp host 4.2.2.1 eq domain any
access-list 105 permit icmp any any echo-reply
access-list 105 permit icmp any any time-exceeded
access-list 105 permit icmp any any unreachable
access-list 105 permit udp host 208.93.226.208 eq 5060 any
access-list 105 permit udp host 208.93.226.208 any eq 5060
access-list 105 permit udp host 208.93.227.208 eq 5060 any
access-list 105 permit udp host 208.93.227.208 any eq 5060
access-list 105 permit udp host 208.93.224.224 eq 5060 any
access-list 105 permit udp host 208.93.224.224 any eq 5060
access-list 105 permit udp host 208.93.226.214 eq 5060 any
access-list 105 permit udp host 208.93.226.214 any eq 5060
access-list 105 permit udp host 192.168.10.1 eq 5060 any
access-list 105 permit udp host 192.168.10.1 any eq 5060
access-list 105 permit udp host 208.93.224.230 eq 5060 any
access-list 105 permit udp host 208.93.224.230 any eq 5060
access-list 105 permit udp any any range 16384 32767
access-list 105 deny ip 10.0.0.0 0.255.255.255 any
access-list 105 deny ip 172.16.0.0 0.15.255.255 any
access-list 105 deny ip 192.168.0.0 0.0.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip any any log
snmp-server community public RO
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server S00105000200.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
tftp-server term71.default.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:CP7921G-1.0.4.LOADS
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.loads
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/phones/7945_7965/apps45.8-4-1-23.sbn alias apps45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-4-1-23.sbn alias cnu45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-4-1-23.sbn alias cvm45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-4-1-23.sbn alias dsp45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-4-1-23.sbn alias jar45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.8-4-2S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
control-plane
bridge 1 route ip
bridge 100 route ip
call threshold interface FastEthernet0/0 int-calls low 3 high 3
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
connection plar opx 105
description Configured by CCA 4 FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-Custom-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
shutdown
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
codec g711ulaw
codec g711alaw
maximum sessions 4
shutdown
dial-peer cor custom
name internal
name local
name domestic
name international
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 200
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 2002 voip
description ** cue prompt management number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 300
b2bua
codec g711ulaw
no vad
dial-peer voice 54 pots
corlist outgoing call-local
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
port 0/1/0
forward-digits 7
no sip-register
dial-peer voice 55 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 56 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 57 pots
description **CCA*North American*Local Number**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 58 pots
description **CCA*North American*Long Distance**
preference 5
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 59 pots
description **CCA*North American*International Number**
preference 5
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 60 pots
description **CCA*North American*Emergency Number**
preference 5
destination-pattern 9911
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 61 pots
preference 5
destination-pattern 9[2-9]11
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 62 pots
preference 5
port 0/1/1
forward-digits 7
no sip-register
dial-peer voice 63 pots
preference 5
port 0/1/1
prefix 1
no sip-register
dial-peer voice 64 pots
preference 5
port 0/1/1
prefix 011
no sip-register
dial-peer voice 65 pots
preference 5
destination-pattern 911
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 66 pots
preference 5
destination-pattern 99911
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 67 pots
preference 5
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 68 pots
description **CCA*North American*Service Number**
preference 5
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 69 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 70 pots
preference 5
port 0/1/2
forward-digits 7
no sip-register
dial-peer voice 71 pots
preference 5
port 0/1/2
prefix 1
no sip-register
dial-peer voice 72 pots
preference 5
port 0/1/2
prefix 011
no sip-register
dial-peer voice 73 pots
description ** FXO pots dial-peer **-Emergency dial-peer
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 74 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 75 pots
preference 5
port 0/1/2
forward-digits 4
no sip-register
dial-peer voice 76 pots
preference 5
port 0/1/2
forward-digits 4
no sip-register
dial-peer voice 77 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 78 pots
preference 5
port 0/1/3
forward-digits 7
no sip-register
dial-peer voice 79 pots
preference 5
port 0/1/3
prefix 1
no sip-register
dial-peer voice 80 pots
preference 5
port 0/1/3
prefix 011
no sip-register
dial-peer voice 81 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 82 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 83 pots
preference 5
port 0/1/3
forward-digits 4
no sip-register
dial-peer voice 84 pots
preference 5
port 0/1/3
forward-digits 4
no sip-register
dial-peer voice 85 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
session target sip-server
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
preference 2
session target dns:nd01-03.fs.broadvox.net
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1029 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1030 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1031 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1032 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1033 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1034 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1035 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
direct-inward-dial
dial-peer voice 2001 voip
description ** cue auto attendant number **
destination-pattern 105
b2bua
codec g711ulaw
no vad
dial-peer voice 3002 voip
description CVMS_Three-OP
translation-profile incoming CVMS_Three-OP_Called_6
incoming called-number 216xxxxxxx
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3003 voip
description CVMS_Two-OP
translation-profile incoming CVMS_Two-OP_Called_7
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1002 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 voip
description CVMS_Main-OP
translation-profile incoming CVMS_Main-OP_Called_4
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 450 voip
description **cue prompt management number**
destination-pattern 450
codec g711ulaw
no vad
no dial-peer outbound status-check pots
sip-ua
credentials username
no remote-party-id
retry invite 2
retry register 10
timers expires 1500000
timers connect 100
timers register 150
registrar dns:nd01-03.fs.broadvox.net expires 120
sip-server dns:nd01-03.fs.broadvox.net
host-registrar
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
video
no auto-reg-ephone
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Chagrin Valley Medical Services
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7945 SCCP45.8-4-2S
load 7965 SCCP45.8-4-2S
time-zone 12
voicemail 200
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold_10db.au
multicast moh 239.10.16.16 port 2000
web admin system name Admin secret 5 $1$0XB/$GqjtpIUpclOJU4XDNmFuG1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
night-service date May 31 00:00 23:59
night-service date Jul 5 00:00 23:59
night-service date Sep 6 00:00 23:59
night-service date Nov 25 00:00 23:59
night-service date Nov 26 00:00 23:59
night-service date Dec 23 00:00 23:59
night-service date Dec 24 00:00 23:59
directory last-name-first
directory entry 1 91216xxxxxxx name SCC
directory entry 2 91440xxxxxxx name Dr. Fitzgerald Mobile
create cnf-files version-stamp 7960 Apr 15 2011 14:26:10
ephone-template 1
softkeys idle Redial Newcall Cfwdall Gpickup
softkeys seized Redial Endcall Cfwdall Pickup
softkeys alerting Callback Endcall
softkeys connected Hold Endcall Trnsfer Park Confrn
ephone-template 15
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 101 no-reg primary
description IP-Paging1
name Intercom
paging ip 239.1.1.1 port 2000
ephone-dn 5 dual-line
number 301 no-reg primary
label 301
description DrFax Fitzgerald
name DrFax Fitzgerald
ephone-dn 9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn 10 octo-line
number 113 no-reg both
label CVMS-3
description CVMS-3
name CV Medical
call-forward busy 114
call-forward noan 114 timeout 10
ephone-dn 11 dual-line
number 120 no-reg primary
pickup-group 1
label CVMS Billing x 120
description CVMS Billing
name CVMS Billing
call-forward busy 200
call-forward noan 200 timeout 10
ephone-dn 12 dual-line
number 150 no-reg primary
pickup-group 1
label Dr Fitzgerald x 150
description Dr Fitx
name Dr Fitzx
ephone-dn 13 dual-line
number 140 no-reg primary
label CVMS Nurse x140
description CVMS Nurse
name CVMS Nurse
call-forward busy 105
ephone-dn 14 dual-line
number 109 no-reg primary
label 109
description B phone
name B phone
ephone-dn 15 dual-line
number 130 no-reg primary
pickup-group 1
label Debbie x 130
description Debbie xxxx
name Debbie xxxx
ephone-dn 16 dual-line
number 160 no-reg primary
label 160
description DrIPC Fitx
name DrIPC Fitx
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description CIPC Fitx
name CIPC Fitx
ephone-dn 20 dual-line
number 112 no-reg both
label CVMS-2
description 112
name CVMS_2
call-forward busy 113
call-forward noan 113 timeout 10
huntstop channel
ephone-dn 22 dual-line
number 107 no-reg primary
label Reception Line 2
description A phone
name A phone
ephone-dn 25
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 200
ephone-dn 41 octo-line
number 111 no-reg both
label CVMS 1-111
description CV Medical
name CV Medical
call-forward busy 112
call-forward noan 112 timeout 15
ephone-dn 42 octo-line
number 114 no-reg both
label CVMS-4
description CVMS-4
name CV Medical
call-forward noan 6111 timeout 6
ephone-dn 43 octo-line
number 170 no-reg both
label Lunchroom - 170
description Lunchroom
name Lunch Room
call-forward noan 111 timeout 20
ephone-dn 44
number 216xxxxxxx
description SIP Main Number registration
preference 1
ephone-dn 45 dual-line
number C002 no-reg primary
conference ad-hoc
preference 1
ephone-dn 46 dual-line
number C001 no-reg primary
conference ad-hoc
preference 1
ephone-dn 47 dual-line
number C003 no-reg primary
conference ad-hoc
preference 1
ephone-dn 48 dual-line
number C004 no-reg primary
conference ad-hoc
no huntstop
ephone-dn 49 dual-line
conference ad-hoc
no huntstop
ephone-dn 50 dual-line
conference ad-hoc
no huntstop
ephone-dn 51 dual-line
conference ad-hoc
preference 1
ephone-dn 52 dual-line
conference ad-hoc
no huntstop
ephone-dn 53
number 702 no-reg primary
park-slot
ephone-dn 54
number 701 no-reg primary
park-slot
ephone-dn 55
number A801... no-reg primary
mwi off
ephone-dn 56
number A800... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address Ex
ephone-template 16
max-calls-per-button 2
username "DrFax" password null
type anl
button 1:5
ephone 2
mac-address 0019.560C.A450
ephone-template 16
username "Lunch" password 123456
type 7960
button 1:43 2:20
ephone 4
mac-address 001D.A23E.C95C
ephone-template 16
paging-dn 1
type 7970
button 1:41 2:20 3:10 4:42
button 6m15 7m13 8m12
ephone 6
video
mac-address 0023.0434.9354
ephone-template 16
username "Billing" password
paging-dn 1
type 7945
button 1:11
ephone 7
video
mac-address 0023.0434.9306
ephone-template 1
username "DrFitz
type 7945
button 1:12
ephone 8
video
mac-address 0023.0434.A22D
ephone-template 16
username "Nurse"
paging-dn 1
type 7945
button 1:13 2:20
ephone 9
video
mac-address 001A.4B7B.5352
ephone-template 1
username "DrFitxCIPC" password null
mtp
type CIPC
button 1:17
ephone 10
video
mac-address 001E.4C78.24C1
ephone-template 16
username "Debbie" password null
mtp
type CIPC
button 1:15 2:20 3:12
ephone 11
video
mac-address 0000.0060.4CAA
username "DrFitx-IPC" password null
mtp
type CIPC
button 1:16
ephone 12
mac-address B8FA.AC9C.0000
ephone-template 16
username "Aphone"
type anl
button 1:22
ephone 13
mac-address B8FA.AC9C.0001
ephone-template 16
username "Bphone"
type anl
button 1:14
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCCisco Configuration Assistant. Version: 1.8. Wed Oct 08 16:38:58 EDT 2008^C
line con 0
privilege level 15
password 7 x
logging synchronous level all
no modem enable
line aux 0
line 2
password 7 x
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input telnet ssh
transport output telnet ssh
line vty 5 100
ntp master
end
CVMS-UC520#
10-06-2011 12:59 PM
Paul,
codec g711ulaw
codec g711alaw
maximum sessions 4
shutdown
Thank you,
Darren
10-06-2011 01:07 PM
Darren, thank you. I will do it via CCA and let you know the outcome.
Paul
10-07-2011 05:18 AM
Darren, I did what you suggested and will verify it worked later when I check with the customer. thank you for your help. Paul
Current configuration : 61012 bytes
! Last configuration change at 22:28:45 EDT Thu Oct 6 2011 by admin
! NVRAM config last updated at 21:16:23 EDT Wed Oct 5 2011 by admin
version 15.0
no service pad
service internal
hostname -UC520
boot-start-marker
boot-end-marker
enable secret 5 .
aaa new-model
crypto pki trustpoint TP-self-signed-216xxxxxxx
subject-name cn=IOS-Self-Signed-Certificate-216xxxxxxx
crypto pki certificate chain TP-self-signed-216xxxxxxxx
quit
dot11 syslog
dot11 ssid xxx-Wireless
vlan 1
authentication open
guest-mode
wpa-psk ascii 7 xxx
ip source-route
ip cef
ip dhcp pool phone
ip dhcp pool data
import all
dns-server xxxx
no ipv6 cef
stcapp ccm-group 1
stcapp
port 0/0/0
fallback-dn 107
port 0/0/1
fallback-dn 109
port 0/0/2
fallback-dn 108
voice rtp send-recv
voice service voip
sip
no update-callerid
voice class codec 1
dualtone conference
frequency 400 800
dualtone conference
frequency 600 900
max-dn 56
max-pool 14
access-list 2
access-list 3
voice translation-rule 5
rule 1 /216xxxx8/ /105/
voice translation-rule 8
rule 1 /216xxxx/ /105/
voice translation-rule 9
rule 1 /2167xxxxx/ /105/
rule 15 /^...$/ /216xxxx/
rule 1 /.*/ //
rule 1 /^9/ //
rule 1 /^6/ //
voice translation-profile CVMS-2-AA_Called_8
translate called 8
voice translation-profile CVMS-3-AA_Called_9
translate called 9
voice translation-profile CVMS_MAIN-1-AA_Called_5
translate called 5
voice-card 0
dspfarm
license udi pid UC520W-8U-4FXO-K9 sn FHK11415A48
archive
log config
logging enable
logging size 600
hidekeys
username Admin privilege 15xxxx
process-max-time 50
match ip dscp af31
match ip dscp ef
match protocol sip
match protocol rtp
match dscp ef
match protocol rtp
class Voice
priority percent 99
set dscp ef
policy-map EthOut
class RTP
set cos 5
set cos 3
encr 3des
group 2
key CVMSvpn1
dns 6xxx
pool SDM_POOL_1
max-users 10
virtual-template 3
bridge irb
interface Loopback0
ip nat inside
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
no ip address
ssid CVMS-Wireless
channel 2462
station-role root
bridge-group 1
ip unnumbered BVI1
ip nat inside
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip nat inside
interface BVI100
ip nat inside
ip http server
access-list 3 permit xxxx
access-list 10 permit xxx
access-list 105 permit udp host x any eq 5060
access-list 105 permit udp host 2xxx any eq 5060
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
description Configured by CCA 4 FXO-0/1/0-Custom-OP-AA
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-Custom-OP-AA
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom-OP-AA
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom-OP-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
shutdown
sccp
sccp ccm group 1
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum conference-participants 32
maximum sessions 2
name internal
name local
name domestic
name international
member internal
member local
member domestic
member internal
member internal
member local
member internal
member local
member domestic
member internal
member local
member domestic
service stcapp
port 0/0/0
service stcapp
port 0/0/1
service stcapp
port 0/0/2
service stcapp
port 0/0/3
port 0/4/0
no sip-register
b2bua
codec g711ulaw
no vad
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
b2bua
codec g711ulaw
no vad
preference 5
port 0/1/0
forward-digits 7
no sip-register
preference 5
port 0/1/0
prefix 1
no sip-register
preference 5
port 0/1/0
prefix 011
no sip-register
preference 5
port 0/1/0
forward-digits all
no sip-register
preference 5
port 0/1/0
forward-digits all
no sip-register
preference 5
port 0/1/0
forward-digits all
no sip-register
preference 5
port 0/1/0
forward-digits all
no sip-register
preference 5
port 0/1/0
forward-digits 3
no sip-register
preference 5
port 0/1/1
forward-digits 7
no sip-register
preference 5
port 0/1/1
prefix 1
no sip-register
preference 5
port 0/1/1
prefix 011
no sip-register
preference 5
port 0/1/1
forward-digits all
no sip-register
preference 5
port 0/1/1
forward-digits all
no sip-register
preference 5
port 0/1/1
forward-digits all
no sip-register
preference 5
port 0/1/1
forward-digits all
no sip-register
preference 5
port 0/1/1
forward-digits 3
no sip-register
preference 5
port 0/1/2
forward-digits 7
no sip-register
preference 5
port 0/1/2
prefix 1
no sip-register
preference 5
port 0/1/2
prefix 011
no sip-register
preference 5
port 0/1/2
forward-digits 3
no sip-register
preference 5
port 0/1/2
forward-digits 3
no sip-register
preference 5
port 0/1/2
forward-digits 4
no sip-register
preference 5
port 0/1/2
forward-digits 4
no sip-register
preference 5
port 0/1/2
forward-digits 3
no sip-register
preference 5
port 0/1/3
forward-digits 7
no sip-register
preference 5
port 0/1/3
prefix 1
no sip-register
preference 5
port 0/1/3
prefix 011
no sip-register
preference 5
port 0/1/3
forward-digits 3
no sip-register
preference 5
port 0/1/3
forward-digits 3
no sip-register
preference 5
port 0/1/3
forward-digits 4
no sip-register
preference 5
port 0/1/3
forward-digits 4
no sip-register
preference 5
port 0/1/3
forward-digits 3
no sip-register
permission term
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
session target dns:nd01-03.fs.xx
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
session target dns:nd01-03.fs.xxx
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
direct-inward-dial
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
dial-peer voice 3001 voip
description CVMS_MAIN-1-AA
translation-profile incoming CVMS_MAIN-1-AA_Called_5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3004 voip
description CVMS-2-AA
translation-profile incoming CVMS-2-AA_Called_8
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3005 voip
description CVMS-3-AA
translation-profile incoming CVMS-3-AA_Called_9
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username xx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers register 150
registrar dns:nd01-03.fs.xxxt expires 120
sip-server dns:nd01-03.fs.xxx
host-registrar
telephony-service
sdspfarm units 5
conference hardware
video
no auto-reg-ephone
authentication x
max-ephones 14
max-dn 56
system message xxxxxs
time-zone 12
voicemail 200
multicast mohxxxxx port 2000
web admin system name Admin secret 5 xxxx
dn-webedit
time-webedit
transfer-pattern .T
night-service date May 30 00:00 23:59
night-service date Jul 4 00:00 23:59
night-service date Sep 5 00:00 23:59
night-service date Nov 24 00:00 23:59
night-service date Dec 26 00:00 23:59
night-service date May 28 00:00 23:59
night-service date May 29 00:00 23:59
directory entry 1 91216xxxx0 name SCC
directory entry 2 91440xxxx name Dr. Fx
ephone-template 1
ephone-template 15
softkeys seized Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn ConfList RmLstC Acct Park Select Join
ephone-template 16
ephone-template 17
ephone-template 18
ephone-dn 1
