Unified CallConnector- Dial Plan how-to?
tuandatnv
I just installed Unified CallConnector in our Windows XP, make call with internal number was OK, but when try dial any other number such Local, Local Plus, National, National Plus..., which I have defined with UC520 I always get busy tone.
It seem that wrong information with Unified CallConnector with Dial Plan setting : There are "Windows Dialling Rule" and "Number Pattern"
Please help to give sample of setting these option for
Call local number such 5111111 with Second Dial Tone 9
Call national number such 240-5111111 with Second Dial Tone 9
Thank you
Tony Huynh
Level 4
Level 4
Are you using the UCC client in personal mode or with the UCC server?
I currently just use UCC in personal mode only
Go to Start > Control Panel > Phone and modem options
On the General Tab, click edit and enter your area code, and enter 9 in the 2 boxes for local and long distance calls.  For international calls, enter 9011.
