Universal Call Connector over VPN
aapexisinc
I'm trying to get the UCC 1.5 to work at the remote end of a VPN (871 -> UC520, with one 7941 phone, which works perfectly).  When I attempt to verify registration, etc., it can ping and find the CME router, but then times out and returns a message that it cannot read the expected reply.  I expect that there is either a port-forwarding or ACL issue in play here.  Can anyone point me in the right direction to get this to work?
15 Replies 15
John Platts
Level 4
Level 4
I have been able to use a single CallConnector Server with site-to-site VPNs, even with multiple UC520 units.
Here is one of the ways to do site-to-site VPNs, and I know that this configuration works on the UC500 and ISR platforms:
crypto keyring AtoB-Keyring
pre-shared-key address key
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp profile AtoB-KeyProfile
   match identity address 255.255.255.255
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile AtoB-Tunnel
set transform-set ESP-3DES-SHA
set isakmp-profile AtoB-KeyProfile
interface Tunnel0
description Site A to Site B tunnel
ip unnumbered BVI1
tunnel source FastEthernet0/0
tunnel destination
tunnel mode ipsec ipv4
tunnel protection ipsec profile AtoB-Tunnel
ip route Tunnel0
The following constraints apply to this setup:
  • Subnets connected through the VPN connection must be unique across all of the sites
  • You need to expose Data and Voice subnets for CallConnector and VPIM functionality
  • Difficult to set up without static IP addresses at the sites using site-to-site VPNs
