Hi,Is it possible to connect SPA9000 with Cisco Call Manager using the SIP Trunk?If possible, please share the method to do it.Thank you.Regards,Willy
Stupid me I installed the UCC Client on a PC while I was logged in as admin, now when I login as the client it will not start and I do not have the rights to start the services. Is there a way to modify an already installed copy to say run as non-adm...
Hi Folks,I have a SIP provider that is working great for calls in & out except to Voicemail, which is a big problem.can someone help with transcoding set-up for Unity Express, I already have transcoding enabled for Meetme etc, anyone done this? How ...
Hello,I am trying to find out which ones of Cisco Small Business Pro phones support video - could you please give me a list of them or a link to related documentation? Do these phones works with Cisco Unified Video Advantage or is there some other SW...
Hi All,Just wondering if anyone else has had this problem or has come across this in the past.I have a customer with a Samsung 7200 Officeserv PBX connected to an SPA8000. Randomly, every 15-20 minutes they will get a phantom call on their PBX from t...
Dear Community:i am using an spa-2100 along with other devices. i have DI-624 router and ftp server software running on a WinXPProSP2 box. when i connect through the router from other macines connected to the router, all is fine. when i connect to my...
I have a Polycom conference phone that we would like to use the Live Record feature with and do not know if it is supported. Is there a "hookflash" command summary available for analog devices?Thanks for your assistance,Kelly
Greetings,I have a client with a SPA8000 latest firmware version having the following issues.This is a first time implementacion, and he is registering to his own PBX IWATSU.He also has a VPN tunnel from a remote location to where the PBX is at. When...
does anyone have documentation how this is usedit seems when doing this it is trying to login to the provsioning page given in Profile_Ruleif using no Digest auth, the EM says it's logged in and will reboot the phoneif turning on Digest auth, it seem...
Will the SPA932 be supported with the SPA525G phone on the UC520 in SCCP mode? The command for configuring the SPA525G with a SPA932 would be similar to the following when such feature is supported:ephone 1device-security-mode nonevideomac-address 00...
We have a uc520, 7.03, with 4 handsets.The system is connected to a bri ISDN 2e.When a user dials externally, the first call always recieves the fast/busy tone, if the user redials the same number the second time, the call successfully connects???Thi...
Hi Allat the moment i configuring 9000 box with Mediatrix 4402and hve difficulty with incoming calls , using step - by - step instruction but didnt recieve calls , software SPA 6.1.51. Outgoing calls fine2. when i make debug on gateway it show that l...
I enabled call accounting on a UC520-48U-T/E/F-K9 with Ver 12.4(20) T2The voip leg record always gives the network out of order (38) error and no call duration. So we can not have a record of the calling number with called number and call duration.T...
What are my options here? Are there any versions compatible with x64?
(Prefer Alberto Montilla)Good day!We test equipment SPA2102 and we have problems in passing faxes.Fax works only in automatic mode without raising a voice session.Fax does not go with the reference in the manual mode on a protocol T38.When I try to c...
