01-25-2010 07:45 AM - last edited on 03-25-2019 10:46 PM by ciscomoderator
This is a follow up to this question I had about incoming call blocking. I did follow the instructions provided and was able to get it to work. The problem I'm running into now is that there is a limit of 15 rules under each voice translation-rule. I need to block more than 15 numbers, but do not want to block entire area codes and prefixes.
Is there a work around for this?
Thanks;
Richard
01-26-2010 08:18 AM
Hi Richard,
The only workaround is to make your rule less specific. You could also manipulate the dial peer matching and have them use different block rules, but this is complicated.
Marcos
01-26-2010 12:39 PM
Hey Marcos;
Thanks for your help. Not sure what my next step is from here, but this has been a good learning exercise.
Richard
