DTMF Outbound Issues on UC520 and XO SIP since upgrade to 15.0.1.XA
johnconrick
We were on 12.24YB and had this issue sporadically, and on 12.20T and never had this occur but what is happening is when you call WebEx for example and have to enter your meeting number, the tones (although you hear them locally) do not carry over and the remote system does not respond.  We just upgraded to 15.0.1XA on Sunday and this issue is now repeatable on all outbound DTMF - inbound works fine.  Attached is a copy of current running config and debug logs.  There were other calls in the system while I was running debug - my test was from Ext 760 (Extra Desk) to 4721724 (also a cisco uc520 system) and trying to dial 2003 (direct extension) and it was not registering the tones.
8 Replies 8
johnconrick
we have 2 polycom soundstation 2w phones in user mode and DTMF tones are working on them.  All our other phones are 7975 and DTMF is not working there.
johnconrick
Question in case the powers that be lose patience with this outbound DTMF issue:
if i change:
boot system flash uc500-advipservicesk9-mz.150-1.XA
to
boot system flash uc500-advipservicesk9-mz.124-20.T2.bin
after uploading the T2 fimware to flash and reset the UC520 that will rollback to T2 firmware right?  Will the newer versions of CUE, CME etc still work with the T2 firmware?
johnconrick
Here is the invite (our UC520) and ringing (XO) from the Debug , it does look like the remote end is a Sonus gateway:
INVITE
sip:4721724@207.155.153.33:5060
SIP/2.0
Via: SIP/2.0/UDP 65.44.247.10:5060;branch=z9hG4bK24BB199C
Remote-Party-ID: "Extra Desk" <
sip:6153454700@65.44.247.10
>;party=calling;screen=no;privacy=off
sip:6153454700@207.155.153.33
>;tag=A7D905C-1984
To: <
Date: Mon, 11 Jan 2010 16:15:11 GMT
Call-ID: 53F07687-FE0311DE-85ED91C9-B9005EF3@65.44.247.10
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1388947808-4261614046-2246611401-3103809267
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1263226511
Contact: <
sip:6153454700@65.44.247.10:5060
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 7027 876 IN IP4 65.44.247.10
s=SIP Call
c=IN IP4 65.44.247.10
t=0 0
m=audio 18888 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
000901: Jan 11 16:15:11.483: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
>;tag=A7D905C-1984
To: <
>;tag=gK02b57704
CSeq: 101 INVITE
Content-Length: 0
000902: Jan 11 16:15:12.547: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
>;tag=A7D905C-1984
To: <
>;tag=gK02b57704
CSeq: 101 INVITE
Contact: <
A lot of us are experiencing the same issues with this software release using SIP providers who have Sonus gateways.
There is a popular thread here:
https://www.myciscocommunity.com/thread/4945
And the Cisco Bug ID here:
http://ww.cisco.com/cgi-bin/Support/Bugtool/home.pl
CSCtd68173
Cisco says they are working on a fix for this issue, so we are hopeful there will be a fix soon.
Checking on this now.
Yes, we have seen this bug and are working on a fix.  It will be included in the 8.0.1 software pack.  This bug wasn't as straight forward as most from a coding side.  There will be an announcement here for when it is fixed.
I know it's hard to speculate on the release timeframe, but do you think we will see 8.0.1 released at some point this quarter?
Yes, we are just days away from releasing this version.
Marcos
