VPN Problem with UC560 and SRP541W
AquaLabs2010
Good morning,
I explain the problem that i have and i am not able to find the solution.
In the central office i have a UC560, we want to connect from a remote office some SPA504 and 7962 phones directly to the UC560, we want that the remote office be as a part of the central office. I understand that we must use a Site to Site VPN.
For the Site to Site VPN we installed a SRP541W in the remote office. I understand that this device is right for this.
Well, the problem is that once installed and configured the SRP541W for the Site to Site VPN, the SRP541W indicates that the VLAN Data is connected, but the rest of VLANs and phones are not connect.
I've done a thousand tests IPSec policies and ACL but i can not find the solution.
Does anyone know or can tell me where i am failing or how i must to configure it?
Data and settings that i configured:
UC560
WAN Address              xxx.xxx.xxx.1
VLAN DATA (1)            10.14.100.1/24
VLAN VOICE (100)       10.1.20.1/24
VLAN CUE (90)            10.1.10.2/30
SRP541W
WAN Address              xxx.xxx.xxx.2
VLAN DATA (1)            10.24.10.1/24         DHCP Data        10.24.10.0/24
VLAN VOICE (100)       10.24.20.1/24         DHCP Voice       10.24.20.0/24       Manual TFTP    10.1.10.2
UC560 Site to Site
SITE1
UC500 Data VLAN IP Address           10.14.100.1/24
VPN Only
SITE2
UC500 Data VLAN IP Address           10.24.10.1/24
VPN Only
SRP541W
IPSec Policy
Policy DATA
Remote Endpoint           xxx.xxx.xxx.1
Local IP Group              10.24.10.0/24
Remote IP Group           10.14.100.0/24
Policy VOICE
Local IP Group              10.24.20.0/24
Remote IP Group           10.1.20.0/24
Policy CUE
Remote IP Group           10.1.10.0/30
Policy DATA status is connected, other are not connect
Thank you very much for all your help
Best Regards
Miguel
bkwon
with my first glance, you better consolidate voice and cue into 1 policy
Policy VOICE
Policy CUE
change to
Policy voice/CUE
Remote IP Group           10.1.0.0/16
please let me know the result.
Dear Bongsu,
Thanks for your help, same result, second policy doesnt connect, only connect the first policy (Policy DATA), i tried to put this policy in first place but in this case the vpn doesnt come up.
you have to consolidate UC560 side as well, both side should be matched for SA exchange.
crypto map multisite 1 YYY
match address XXX
access-list XXX permit ip 10.1.0 0.0.255.255 10.24.20.0 0.0.0.255
also ip nat acl should be adjust like...
access-list 105 deny   ip 10.1.0 0.0.255.255 10.24.20.0 0.0.0.255
