To all,We have a new UC540 install with 12 IP Communicator Clients. We are using Jabra ..... headsets. We have encountered a challenge with Windows 7 PCs that this is solution is installed on. The user would like to be able to use the PC Speaker/...
Hi,Just thought I would share how to integrate a Cisco UC560 PBX with Office 365 to provide voicemail to email inbox functionality.The First thing to do is to set up an smtp virtual in IIS on a server within the environment according to Microsoft's K...
Hi all,Im coming to the end of the setup of our UC320w/ spa504G system and having one remaining problem.Iv successfully setup and assigned inbound lines 5 from sip trunk and 1 from a fxo line.For reference our 5 in bound sip lines end in 95/96/97/98/...
We have had a few only going issues with these devices since having to change to them when the 2102 was discontinued. At this stage we have two issues: 1. Provisioning via TFTP causes the bridge mode in the device to not work, we have got a beta rel...
Hi friends ; Im stuck in configuring an SPA8800 in order to proccess a call coming from UC560 via a SIP trunkUC560 Dialpeer Configdial-peer voice 100 voip description llamadas_nacionales destination-pattern 7500900 redirect ip2ip session protocol si...
i have a new client with a uc540 setup and there is 3 phones. 1 phone offsite at a remote location with an spa525g2 with ssl vpn, and when she (the remote user) calls someone every so often the conversation stops, i called her to see how it was worki...
Hi Guys,Is it possible to automatically remove voicemails after they expire? We have them on GDMs and the GDM becomes full, we stop getting voice to email. They expire after 15days, so we'd like them to be automatically deleted after this date.
We have a UC560 with a front desk admin that transfers calls to the users.Some of these calls end up in voice mail.When the user retrives one of these voicemails, they get a lengthy system recording preamble along the lines of "Call transfered by XXX...
I have a customer whose Voicemail-to-Email is not working.I was able to locate the error below in the system logs -- but it's too vague to really tell me what is going on.Anyone have any insight into what this means?Jul 2 10:40:21 UC320W user.debug ...
I’ve got a SPA504G with Asterisk PBX and broadband.com SIP service. I can recieve calls fine on the handset, but when I make outbound calls, about half of the calls have one way audio or no-way audio. When I have audio problems, I can hit the hold bu...
Hello.BE 3000 (8.6.3), Russian packInternal GW (E1 PRI) conected to PSTN. For calls (local,mobile, toll free, long distance) the operator require only pass 10 digits (format is {area code}{local number})By default the BE 3000 pass 11 digits as the fi...
Hello,I have a cisco 887W router with several SPA504 phones that are not able to fully register to send and receive calls, inbound the phones will ring but no audio heard either way.At the moment I have NAT'd udp 5060 direct to a single phone and tur...
UC540SP 8.6.0Can the Intersite Dialing Prefix be different for the sites?For example, can Site 1 use an Intersite Dialing Prefix of '4', and Site 2 use an Intersite Dialing Prefix of '7'?Or does the Intersite Dialing Prefix have be '4' for both Site ...
