WIP310 Fails To Re-Register.
juunda
Customer has several WIP310 connected wirelessly to an accesspoint and then to a internal PBX Tribox V2.6.22. Using Teliax ITSP.
The phones work great for a while but randomly fail to re-register. The only way for it to work again is to power cycle the device.   Customer has tried three diferent access point in order to elimate the possibility of bad wireless connectivity. Has latest firmware 5.0.11
Please advice in any way possible thanks in advance.
233 Replies 233
aguzman82
Thanks for the update Pat!
However I tried upgrading the phone, and im getting a popup:
"Device disconnected!
Please remove and replug USB with the phone, and then run again!"
Tried different usb cables, different usb ports on my computer (Windows 7, regular run, and running with administrative privilages) and on my HTPC computer (windows Vista) with the same behaivor. Phone is fully charged and off. the lcd screen is on at all times (with the battery icon with either charging or the checkmark that is fully charged), so it isnt really disconnecting from the PC. Any idea what could be happening?
Hi Alex,
A normal USB cable should suffice. I'm using a cable that came with my Nikon camera.
Make sure that you do not use the phone cradle. Computer USB port > cable > bottom of phone
I ran with success on XP. I'll test on Windows 7 and report back.
Patrick
This worked fine for me first time...  Now just sitting watching the phone...
Upgrade process:
Phone was powered off.
I placed the Flashman folder on my desktop and ran the exe.
I then plugged the phone in - I didn't have to turn it on.  Either the Flashman triggered it to power on or it powered on because of USB.
It then found to the phone.
The exe then asked for the Flashman folder location and upgraded.
Peter
reputablesquid
Upgrade went smoothly on Windows XP; no Success with Windows 7.
Are there notes on what specifically this update addresses?
Community,
I confirm that I have the same problem as Alex when trying to use Windows 7, regardless of the compatibility options I choose.
Alternate ways to upgrade are:
1. use a web server
2. use a TFTP server, but if you have a marginal WiFi signal, the update will fail with TFTP due to errors
Syntax is: http:///admin/upgrade?:///wip310-5.0.12-09-09-2009-beta.img
1. HTTP example:  http:///admin/upgrade?http:///wip310-5.0.12-09-09-2009-beta.img
2. TFTP example: http:///admin/upgrade?tftp:///wip310-5.0.12-09-09-2009-beta.img
I don't have a release note available yet. As I mentioned earlier, this is very early test code, so please don't use if you are averse to bugs.
This code was given to me to test against registration problems with trixbox.
Once the fix has been confirmed and the Quality Assurance team have completed testing, the code will be officially released with a release note. [Schedule unknown to me at this time.]
Patrick
Thanks for giving the alternative way to upgrade... just saved me time of installing XP :). So far i was able to flash it with your provided http method.
I'll report back on my first day with this new beta firmware tomorrow..
Well I just got the 'Not regisitered' mesage again on my phone :(
Any particular setting we would need to tweak on the webui ??
Hi Alex,
I'll report back to Eng and let you know.
Thanks for testing.
Patrick
Alex,
I've filed your report against CDETS CSCtc85921 and have linked it to CSCtb34903.
Thanks again for the help.
Patrick
No sure this the right thread. I have a WIP310 and I observed that there is a "Next registration in" counter that starts around 180s and decreases to 0. At the 0 point the phone more often than not moves to the "Not registered" state and then after the "Reg Interval Value" runs down to 0 it re-registers. Is this normal behaviour? If not, who determines the "Next registration in" interval please? Looked in the documentation but was unable to find anything relevant.
Any assistance greatly appreaciated,
Dimitrios
Hi Dimitrios,
No, this is not normal behavior.
The description resembles a bug from an earlier release. Please make sure that the phone is running 5.0.11 available from: https://supportforums.cisco.com/docs/DOC-9923 Registered link or anonymous links available.
The Next Registration interval is controlled by the Phone's Ext 1 tab > Proxy and Registration > Register Expires:
Patrick
Dear Patrick,
I am ledinhan from VietNam,
We also are facing to the same symtomp of 2 WIP310 as this topic...
Poor us, when these units are the first in Viet Nam...
I have tried and successfully updated your early-beta firmware...however, seems symtomp still happenned.
Without 1 dial-out call, WIP310 will fall to sleep mode,then it could not receive incoming call, sometime it go to unregistered status...
Then,if you make 1 dial-out call, it will wake up...or we have to restart phone...!!!
When will the new firmware will come, Pat?WIP310 really become our nightmare...
Another question:
Can we use the latest firmware of WIP320, WIP330 to fix above symtomp of WIP310?
Tks to your response,
Brgds,
ledinhan
WIP300 and WIP320 are totally different devices. The FW are not common.
HI Community,
I updated successfully the test code, however the lost registration was not resolved. Any update about fixing this problem?
Hi fdc.cisco.supports,
I've requested a status on this from Engineering.
Patrick
