03-08-2015 10:14 AM - edited 03-21-2019 08:34 AM
Dear Forum,
I recently startet to setup to SPA 50x phones. So far quite successfully, but there is one thing I could not figure out so far:
I set up a LDAP phone-directory - which basically works. The only weird thing is the order of letters used when entering the searchname.
Example: When I press 2, I expect the order of selectable letters to start with "ABC". But it is "äAB....." so the first letter is an "ä". This is the case for several key always when the first letter of a name is capitalized automatically (so if the 2 is pressed on a later letter the order is OK".
Any idea how to fix this?
Carsten
Solved! Go to Solution.
03-08-2015 11:18 AM
I know no solution, but I can propose some idea to test.
Read German dictionary file (used for phone's provisioning), phrase 3851. It look like definition of key selectable letters. You can try to modify them. It may or may not help. I didn't tried it.
03-08-2015 11:18 AM
04-01-2015 10:26 AM
Thanks for the Hint, that works.
