06-19-2015 09:53 AM - edited 03-21-2019 08:42 AM
I'm unable to send calls to my carrier on POTS lines plugged into the FXO ports. When I dial 7+1+10 I get "that number is not in service..." from the carrier. According to my translation rule I should be sending 1+10. When I plug an analog phone into the line and dial 1+10 the call works fine. What am I missing? Is there any way to confirm that these digits are going out correctly?
------------------ show running-config ------------------
Building configuration...
Current configuration : 44754 bytes
! Last configuration change at 12:46:16 EDT Fri Jun 19 2015 by ucadmin
! NVRAM config last updated at 12:21:59 EDT Fri Jun 19 2015 by ucadmin
version 15.1
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname UC560
boot-start-marker
boot-end-marker
no logging queue-limit
no logging rate-limit
no logging console
no logging monitor
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-965500691
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-965500691
revocation-check none
rsakeypair TP-self-signed-965500691
crypto pki certificate chain TP-self-signed-965500691
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 39363535 30303639 31301E17 0D313231 32313231 38333735
305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3936 35353030
36393130 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
D758F58A D7843066 1A3CA0BB DC97090A C91420D0 349073A0 E093F57F 1E4EC470
4C7701E3 DAAF527D FFC068AB 69790DBA CA577942 603D92DE 79149036 DFFCA113
A26C48E6 0EC8DEA6 89ED6D16 D769AAB8 39AEC987 18550A52 9BB125C8 AE141B74
6F641565 28925404 7C14DA1D 6D9CBA7B 6A2273C5 E0AF4D58 7A22D77E C00B9C67
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
E37B0EE7 392C9A25 F9E7BB87 8B
quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 172.20.58.1 172.20.58.19
ip dhcp excluded-address 172.20.58.241 172.20.58.255
ip dhcp excluded-address 172.30.1.1 172.30.1.10
ip dhcp pool phone
network 172.20.58.0 255.255.255.0
default-router 172.20.58.1
option 150 ip 172.20.58.1
ip dhcp pool Guest-WLAN
network 172.30.1.0 255.255.255.0
default-router 172.30.1.1
dns-server 192.168.0.3 4.2.2.2
no ip domain lookup
ip name-server 4.2.2.2
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 172.20.58.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 12
create profile sync 8071007903605228
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^7/ //
voice translation-rule 2002
rule 1 /^8/ //
voice translation-rule 2222
rule 1 /^71900......./ //
rule 2 /^71976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC560-FXO-K9 sn FGL164513GV
archive
log config
logging enable
logging size 600
hidekeys
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
username ucadmin privilege 15 secret 4 <removed>
username MStOnge password 0 <removed>
username lsilva password 0 <removed>
username lcoughlan password 0 <removed>
username LynnSilva password 0 <removed>
ip ftp username ciscod
ip ftp password <removed>
ip tftp source-interface Vlan90
gw-accounting file
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key <removed>
dns 75.75.75.75 4.2.2.2
pool SDM_POOL_1
save-password
max-users 20
crypto isakmp profile sdm-ike-profile-1
match identity group EZVPN_GROUP_1
client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address 1.1.1.205 255.255.255.248
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
ip verify unicast reverse-path
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 100
no ip address
macro description cisco-switch
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
macro description cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
description $FW_INSIDE$
ip address 192.168.0.5 255.255.255.0
ip access-group 101 in
ip nat inside
interface Vlan30
ip address 172.30.1.1 255.255.255.0
ip access-group Guest-WLAN in
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
interface Vlan100
ip address 172.20.58.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip local pool SDM_POOL_1 172.20.50.10 172.20.50.30
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.1.10.1 25 1.1.1.205 25 extendable
ip nat inside source static tcp 10.1.10.1 143 1.1.1.205 143 extendable
ip nat inside source static tcp 10.1.10.1 465 1.1.1.205 465 extendable
ip nat inside source static tcp 10.1.10.1 587 1.1.1.205 587 extendable
ip nat inside source static tcp 10.1.10.1 993 1.1.1.205 993 extendable
ip route 0.0.0.0 0.0.0.0 1.1.1.206
ip route 10.1.10.1 255.255.255.255 Vlan90
ip access-list extended Guest-WLAN
remark SDM_ACL Category=17
permit udp any host 172.30.1.1 eq non500-isakmp
permit udp any host 172.30.1.1 eq isakmp
permit esp any host 172.30.1.1
permit ahp any host 172.30.1.1
permit udp 172.30.1.0 0.0.0.255 any eq domain
permit tcp 172.30.1.0 0.0.0.255 any eq domain
permit udp 172.30.1.0 0.0.0.255 any eq bootpc
permit udp 172.30.1.0 0.0.0.255 any eq bootps
permit tcp 172.30.1.0 0.0.0.255 host 10.1.10.1 eq 143
deny tcp 172.30.1.0 0.0.0.255 host 172.30.1.1 eq telnet
deny tcp 172.30.1.0 0.0.0.255 host 172.30.1.1 eq 22
deny tcp 172.30.1.0 0.0.0.255 any eq smtp
deny ip 172.30.1.0 0.0.0.255 10.0.0.0 0.255.255.255
deny ip 172.30.1.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip 172.30.1.0 0.0.0.255 172.16.0.0 0.15.255.255
deny ip 127.0.0.0 0.255.255.255 any
deny ip host 255.255.255.255 any
permit ip any any
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.20.58.0 0.0.0.255
access-list 1 permit 172.30.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 192.168.0.5 eq non500-isakmp
access-list 101 permit udp any host 192.168.0.5 eq isakmp
access-list 101 permit esp any host 192.168.0.5
access-list 101 permit ahp any host 192.168.0.5
access-list 101 remark Auto generated by SDM for NTP (123) 69.85.88.32
access-list 101 permit udp host 69.85.88.32 eq ntp host 192.168.0.5 eq ntp
access-list 101 deny ip 74.92.51.176 0.0.0.7 any
access-list 101 deny ip 10.1.10.0 0.0.0.3 any
access-list 101 deny ip 172.20.58.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any host 172.20.58.1 eq non500-isakmp
access-list 102 permit udp any host 172.20.58.1 eq isakmp
access-list 102 permit esp any host 172.20.58.1
access-list 102 permit ahp any host 172.20.58.1
access-list 102 remark Auto generated by SDM for NTP (123) 69.85.88.32
access-list 102 permit udp host 69.85.88.32 eq ntp host 172.20.58.1 eq ntp
access-list 102 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 deny ip 74.92.51.176 0.0.0.7 any
access-list 102 deny ip 192.168.0.0 0.0.0.255 any
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 103 permit udp any host 10.1.10.2 eq isakmp
access-list 103 permit esp any host 10.1.10.2
access-list 103 permit ahp any host 10.1.10.2
access-list 103 remark Auto generated by SDM for NTP (123) 69.85.88.32
access-list 103 permit udp host 69.85.88.32 eq ntp host 10.1.10.2 eq ntp
access-list 103 permit tcp 172.20.58.0 0.0.0.255 eq 2000 any
access-list 103 permit udp 172.20.58.0 0.0.0.255 eq 2000 any
access-list 103 deny ip 74.92.51.176 0.0.0.7 any
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 deny ip 172.20.58.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_16##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit tcp any host 74.92.51.180 eq 465
access-list 104 permit tcp any host 74.92.51.180 eq 587
access-list 104 permit tcp any host 74.92.51.180 eq 993
access-list 104 permit tcp any host 74.92.51.180 eq smtp
access-list 104 permit tcp any host 74.92.51.180 eq 143
access-list 104 permit udp any host 74.92.51.180 eq non500-isakmp
access-list 104 permit udp any host 74.92.51.180 eq isakmp
access-list 104 permit esp any host 74.92.51.180
access-list 104 permit ahp any host 74.92.51.180
access-list 104 remark Auto generated by SDM for NTP (123) 69.85.88.32
access-list 104 permit udp host 69.85.88.32 eq ntp host 74.92.51.180 eq ntp
access-list 104 deny ip 192.168.0.0 0.0.0.255 any
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 172.20.58.0 0.0.0.255 any
access-list 104 permit udp host 4.2.2.2 eq domain any
access-list 104 permit udp host 8.8.8.8 eq domain any
access-list 104 permit icmp any host 74.92.51.180 echo-reply
access-list 104 permit icmp any host 74.92.51.180 time-exceeded
access-list 104 permit icmp any host 74.92.51.180 unreachable
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip host 0.0.0.0 any
access-list 104 deny ip any any log
access-list 104 permit tcp any host 1.1.1.205 eq 465
access-list 104 permit tcp any host 1.1.1.205 eq 587
access-list 104 permit tcp any host 1.1.1.205 eq 993
access-list 104 permit tcp any host 1.1.1.205 eq smtp
access-list 104 permit tcp any host 1.1.1.205 eq 143
access-list 104 permit udp any host 1.1.1.205 eq non500-isakmp
access-list 104 permit udp any host 1.1.1.205 eq isakmp
access-list 104 permit esp any host 1.1.1.205
access-list 104 permit ahp any host 1.1.1.205
access-list 104 permit udp host 69.85.88.32 eq ntp host 1.1.1.205 eq ntp
access-list 104 permit icmp any host 1.1.1.205 echo-reply
access-list 104 permit icmp any host 1.1.1.205 time-exceeded
access-list 104 permit icmp any host 1.1.1.205 unreachable
snmp-server community <removed> RO
snmp-server host 1.1.1.1 <removed>
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/phones/7942_7962/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
station-id name Dn Conf Polycom
station-id number 51
caller-id enable
voice-port 0/0/1
station-id name Mail machine
station-id number 52
caller-id enable
voice-port 0/0/2
station-id name Up Conf Polycom
station-id number 53
caller-id enable
voice-port 0/0/3
station-id number 54
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
no battery-reversal
connection plar opx 60
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
no battery-reversal
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
no battery-reversal
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
no battery-reversal
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/2/0
no battery-reversal
description Configured by CCA 4 FXO-0/2/0-OP
caller-id enable
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 172.20.58.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 51
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 52
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 53
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 54
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 100 pots
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 102 pots
port 0/2/2
dial-peer voice 103 pots
port 0/2/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 104 pots
destination-pattern A4
port 0/2/0
no sip-register
dial-peer voice 105 pots
destination-pattern A5
port 0/2/1
no sip-register
dial-peer voice 106 pots
destination-pattern A6
port 0/2/2
no sip-register
dial-peer voice 107 pots
destination-pattern A7
port 0/2/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 99
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
preference 5
destination-pattern 7911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
prefix 7
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 7[2-9]..[2-9]......
no digit-strip
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 7[2-9]11
no digit-strip
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 71[2-9]..[2-9]......
no digit-strip
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 7011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 71800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71855.......
forward-digits all
no sip-register
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 59
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 62
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
no dial-peer outbound status-check pots
telephony-service
video
authentication credential cisco cisco
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 172.20.58.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message PSDAB
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 12
keepalive 30 auxiliary 4
voicemail 99
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$jm40$FR5/m6sRZ.7kLSJ53nxAp.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 7.T
transfer-pattern 8.. blind
secondary-dialtone 7
night-service code *59
night-service day Sun 00:00 23:59
night-service day Mon 17:00 08:00
night-service day Tue 17:00 08:00
night-service day Wed 17:00 08:00
night-service day Thu 17:00 08:00
night-service day Fri 17:00 08:00
night-service day Sat 00:00 23:59
fac standard
create cnf-files version-stamp 7960 May 13 2015 11:00:18
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 66 no-reg primary
description IP-Paging1
name All Page
paging ip 239.1.1.1 port 2000
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 559 dual-line
number 55 no-reg primary
label Melissa
description Melissa
name Melissa StOnge
call-forward busy 99
call-forward noan 99 timeout 20
ephone-dn 560
number DBA45 no-reg primary
name DialableIntercom45
intercom DBA no-mute label "Intercom"
ephone-dn 561 octo-line
number 41 no-reg primary
label Andrew Fullam
name Andrew Fullam
ephone-dn 562
number DBA38 no-reg primary
name DialableIntercom38
intercom DBA no-mute label "Dialable Intercom"
ephone-dn 563
number DBA24 no-reg primary
name DialableIntercom24
ephone-dn 564
number DBA19 no-reg primary
name DialableIntercom19
ephone-dn 565
number 33 no-reg primary
park-slot timeout 120 limit 2 recall retry 120 limit 2
label Call Park
ephone-dn 566 octo-line
number 30 no-reg primary
label 30
description Dwn Copy Area
name Downstairs Copy
ephone-dn 567
number DBA16 no-reg primary
name DialableIntercom16
ephone-dn 568
number DBA10 no-reg primary
name DialableIntercom10
ephone-dn 569 octo-line
number 37 no-reg primary
label 37
description Peggy Evans
name Peggy Evans
call-forward noan 99 timeout 10
ephone-dn 570 octo-line
number 38 no-reg primary
label 38
description Philomena Hu
name Philomena Hu
ephone-dn 571 octo-line
number 60 no-reg primary
label Office Main
description 60
name Office Main
call-forward busy 59
call-forward night-service 59
call-forward noan 59 timeout 15
night-service bell
ephone-dn 572 octo-line
number 47 no-reg primary
label 47
description Craig Gabri
name Craig Gabri
ephone-dn 573 dual-line
number 16 no-reg primary
label 16
description Downstairs Conference
name Downstairs Conference
ephone-dn 574 dual-line
number 42 no-reg primary
label 42
description Upstairs Conference
name Upstairs Conference
ephone-dn 575 dual-line
number 36 no-reg primary
label Megan Moreland
description PSDAB
name Megan Moreland
ephone-dn 576 dual-line
number 18 no-reg primary
label 18
description Aaron Udvardy
name Aaron Udvardy
ephone-dn 577 dual-line
number 35 no-reg primary
label 35
description Lynne Coughlan
name Lynne Coughlan
ephone-dn 578 octo-line
number 45 no-reg primary
label Aaron Polhemus - 45
description Aaron Polhemus
name Aaron Polhemus
ephone-dn 579 octo-line
number 13 no-reg primary
label Peter Polhemus - 13
description Peter Polhemus
name Peter Polhemus
ephone-dn 580 dual-line
number 24 no-reg primary
label 24
description Sean Mulcahy
name Sean Mulcahy
ephone-dn 581 octo-line
number 10 no-reg primary
label Beth McCormick - 10
description Beth McCormick
name Beth McCormick
ephone-dn 582 dual-line
number 23 no-reg primary
label 23
description Glenn Mitchell
name Kendra Seifert
ephone-dn 583 octo-line
number 19 no-reg primary
label 19
description Richard Manfredi
name Richard Manfredi
ephone-dn 584 dual-line
number 31 no-reg primary
label 31
description Gerry Madden
name Gerry Madden
ephone-dn 585 dual-line
number 28 no-reg primary
label 28
description Deb Guay
name Ryan Richardson
ephone-dn 586 dual-line
number 49 no-reg primary
label 49
description Angela Guarino
name Angela Guarino
ephone-dn 587 dual-line
number 34 no-reg primary
label 34
description Steve Glasheen
name Steve Glasheen
ephone-dn 588 octo-line
number 25 no-reg primary
label Joan Graney
description Joan Graney
name Joan Graney
ephone-dn 589 octo-line
number 11 no-reg primary
label 11
description Allen Furman
name Allen Furman
ephone-dn 590 octo-line
number 40 no-reg primary
label 40
name Alison Farias
ephone-dn 591 octo-line
number 29 no-reg primary
label 29
description Jerry Durr
name Jerry Durr
ephone-dn 592 dual-line
number 22 no-reg primary
label 22
description Heidi Dumais
name Heidi Dumais
ephone-dn 593 dual-line
number 27 no-reg primary
label 27
description Sharon DaSilva
name Sharon DaSilva
ephone-dn 594 octo-line
number 14 no-reg primary
label John DaSilva - 14
description John DaSilva
name John DaSilva
ephone-dn 595 dual-line
number 32 no-reg primary
label John Barker
name John Barker
ephone-dn 596 dual-line
number 20 no-reg primary
label 20
description Richard Craddock
name Richard Craddock
ephone-dn 597 dual-line
number 26 no-reg primary
label 26
description Jeff Brown
name Jeff Brown
ephone-dn 598
number 8.. no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 99
ephone-dn 599
number A801.. no-reg primary
mwi off
ephone-dn 600
number A800.. no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address 8875.5651.9E29
ephone-template 16
username "RCraddock" password 123456
paging-dn 1
type 7942
button 1:596
ephone 2
mac-address 8875.5651.A04E
ephone-template 16
username "BDaly" password 123456
paging-dn 1
type 7942
button 1:595
ephone 3
mac-address F4EA.6748.B466
ephone-template 16
username "JDaSilva" password 123456
paging-dn 1
type 7965
button 1:594
ephone 4
mac-address 8875.5651.9D4E
ephone-template 16
username "SDaSilva" password 123456
paging-dn 1
type 7942
button 1:593
ephone 5
mac-address 8875.5651.8ECD
ephone-template 16
username "JBrown" password 123456
paging-dn 1
type 7942
button 1:597
ephone 6
mac-address 203A.0722.242D
ephone-template 16
username "HDumais" password 123456
fastdial 1 717745219479 name Bruce
fastdial 2 717743277869 name Sean
fastdial 3 715087756588 name Ed Edd
fastdial 4 715087765204 name Becky
fastdial 5 715089457016 name CPS_Amber
paging-dn 1
type 7942
button 1:592
ephone 7
mac-address 8875.5651.9C4B
ephone-template 16
username "JDurr" password 123456
paging-dn 1
type 7942
button 1:591
ephone 8
mac-address 8875.5650.4AB0
ephone-template 16
username "afarias"
type 7942
button 1:590
ephone 9
mac-address 8875.5651.9F15
ephone-template 16
username "AFurman" password 123456
speed-dial 1 715088626240999 label "shepley"
speed-dial 2 715084002349 label "whiteley"
speed-dial 3 715084323959 label "harwich.port"
paging-dn 1
type 7942
button 1:589
ephone 10
mac-address 5478.1AE0.BED1
ephone-template 16
username "JGraney" password 123456
type 7965
button 1:588 2:571
ephone 11
mac-address 203A.0723.5E5F
ephone-template 16
username "SGlasheen" password 123456
paging-dn 1
type 7942
button 1:587
ephone 12
mac-address 203A.0723.72BA
ephone-template 16
username "AGuarino" password 123456
paging-dn 1
type 7942
button 1:586
ephone 13
mac-address 203A.0723.5E5B
ephone-template 16
username "DGuay" password 5555
paging-dn 1
type 7942
button 1:585
ephone 14
mac-address 203A.0723.70ED
ephone-template 16
username "GMadden" password 123456
paging-dn 1
type 7942
button 1:584
ephone 15
mac-address 203A.0722.BB4C
ephone-template 16
username "PUser" password System2014
paging-dn 1
type 7942
button 1:572
ephone 16
mac-address 203A.0723.5DA3
ephone-template 16
username "GMitchell" password 123456
paging-dn 1
type 7942
button 1:582
ephone 17
mac-address 203A.0722.922E
ephone-template 16
username "cburgin" password 1234567
fastdial 1 717747220536 name rick.d
paging-dn 1
type 7942
button 1:569
ephone 18
mac-address F4EA.6748.E93D
ephone-template 16
username "SMulcahy" password 123456
speed-dial 1 5087759211 label "Nancy-Work"
speed-dial 2 5084205554 label "Home"
speed-dial 3 5085601018 label "Nancy-Cell"
paging-dn 1
type 7965
button 1:580 6:563
ephone 19
mac-address C8F9.F9D6.7CB5
ephone-template 16
username "PPolhemus" password 123456
type 7965
button 1:579
ephone 20
mac-address 5478.1AE0.BC93
ephone-template 16
username "APolhemus" password Tahoeduffy31
paging-dn 1
type 7965
button 1:578 6:560
ephone 21
mac-address 203A.0723.68DA
ephone-template 16
username "LynnSilva" password 2580
type 7942
button 1:577
ephone 22
mac-address 203A.0723.5D37
ephone-template 16
username "AUdvardy" password 123456
paging-dn 1
type 7942
button 1:576
ephone 23
mac-address 203A.0723.5E03
ephone-template 16
username "DCopy" password 123456
paging-dn 1
type 7942
button 1:575
ephone 24
mac-address 203A.0723.7433
ephone-template 16
username "UConference" password 123456
paging-dn 1
type 7942
button 1:574
ephone 25
mac-address 203A.0723.5F10
ephone-template 16
username "DConference" password 123456
paging-dn 1
type 7942
button 1:573 2:567
ephone 26
mac-address 5478.1A1D.66E2
ephone-template 16
username "RManfredi" password 123456
paging-dn 1
type 7965
button 1:583 6:564
ephone 27
mac-address 3C0E.236D.263D
ephone-template 16
username "MStOnge" password 1234567
type 7942
button 1:559
ephone 28
mac-address 8478.ACE7.E03F
ephone-template 16
username "DwnCopy" password 123456
type 7965
button 1:566 2:571
ephone 29
mac-address 5CA4.8A64.B9C9
ephone-template 16
username "AFullam1" password 123456
type 7942
button 1:561
ephone 30
mac-address 203A.0723.5AD2
ephone-template 16
username "PHu" password 123456
paging-dn 1
type 7942
button 1:570 2:562
ephone 31
mac-address F4EA.6748.ACF2
ephone-template 16
username "MMorse" password 123456
paging-dn 1
type 7965
button 1:581 2:571 3m578 4m579
button 5m594 6:568
alias exec cca_voice_mode PBX
alias exec s show ip int br
alias exec srt show ip route
alias exec sr show run
alias exec sri show run | i
alias exec srb show run | b
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Fri Jul 19 14:10:26 EDT 2013^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
exec-timeout 60 0
transport input all
line vty 5 100
exec-timeout 60 0
transport input all
ntp master
ntp server 69.85.88.32
end
06-19-2015 10:06 AM
You need to strip the 7 before you send it out to the PSTN. I see you have a translation profile set up but it is not assigned to the dial peer. You need to change the dial peer to forward only 11 digits, instead of all digits as currently configured or you could apply the translation profile you built to strip the 7.
trunkgroup ALL_FXO
preference 5
no digit-strip
forward-digits all
no sip-register
