CFNA Timer on UC500
spollock
Sorry for the likely FAQ, can't seem to locate in the doc anywhere.
I have a UC500 with analog line forwarding to AA.  When AA hands off to an extension it seems to only ring twice, I would like to increase this timer system wide.
I've hacked around in CCA and found nothing related, also the CLI under telephony-services but nothing jumps out there either.
Nothing is turned up via a search either.
Anyone have an idea?
This is done under the ephone-dn:
UC500#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UC500(config)#ephone-dn 1
UC500(config-ephone-dn)#call-forward noan 8888 timeout ?
  <3-60000>  Ringing no answer timeout duration in seconds
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
