Cordless headset for spa525
paulvestuto
I currently have a Plantronics mechanical lifter cordless headset that I use with my Avaya IP phone.
I now have a Cisco IP phone.
Does anyone have a recommendation for a cordless headset that is compatible with a Cisco SPA525g phone?
As I understand it, I can get a Bluetooth headset which would give me about 30 feet of mobility from the phone.
Are there also electronic lifter headsets that work with the SPA525g?  The electronic lifters have a longer range of mobility.
Bluetooth or otherwise- recommendations?
Leonardo Santana
Hello Paul
Look at this discussion:
https://supportforums.cisco.com/message/3233786#3233786
Other discussion taht will help you:
https://supportforums.cisco.com/docs/DOC-9926
Leonardo Santana
Rate this if helps
Leonardo Santana
*** Rate All Helpful Responses***
