Error opening tftp:/// (Invalid IP address or hostname) - fix?
NicP270591
Anyone? I am just trying to access TFTP on my UC520 via CCA Exec Commands to copy some ringtone files across...and I am getting this error after using cmd: copy tftp flash. Phones work fine and load fine, so obviously TFTP is working....what the??
Thanks!
Darren DeCroock
Level 4
Level 4
In CCA, you can not execute commands that require you to be in "enable" mode from the IOS exec page.
If you are just trying to upload a file into flash.  This can now be done in the new version of CCA - 3.0.  File upload was not possible in prior versions of CCA, other than doing it manually with a TFTP or FTP server with CLI.
