Expansion Module
rodeddie01
I wanted to ask if the expansion module for a SPA500 set can also have analog trunks programmed per key.
paolo bevilacqua
Yes. These are simply speed-dials that seize the circuit of your choice.
Thanks!!!
You're welcome, please remember to rate useful posts clicking on the stars below.
David Trad
Hi Eddie,
In CCA you choose the CO-Line option and then assign it to your button of choice, its quite simple and painless exercise
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
