Howto reload localization?
YokavYokav
I'm trying to find a way to reload a localization file which is host on a tftp server.
I'm personnalising this localization file, so I would like to be able to reload it to see the effect of what I modified. But restarting the phone from the setup menu or with an hardware unplug has no effect, like if the localization is still in memory.
The only way that I found is to do a reset factory, which is not very fun...
Any help is welcome.
Alberto Montilla
Dear Christophe;
Solution is to rename the dictionary file and change the server script to point to the new filename.
Alberto
Great, thank you for this quick answer.
