REFER method
Diego Betancor
is there any softkey that would accept digits and then issue a REFER for the transfer os the call?
If not with XSI I can get input, is it posible to send a REFER?, (or a INFO or a NOTIFY anything?)
I am using the 508g (but I would like to use it all the spa50x-30x).
Thanks, Diego
Diego Betancor
I will answer myself. The blind transfer send a REFER.
