04-10-201308:16 AM - last edited on 03-25-201911:05 PM by ciscomoderator
Does anyone know how to restrict the UC500 from using specific outbound FXO ports?
Presently they have 2 ports; 1 for fax services and the other for voice services. However the dial plan ignores the port status and will squentially access the ports to send calls outbound. I need to set priority to always send out the voice port FXO line 0/1/3
I am using CCA and have setup the trunk ports in every possible way (sequential, least active, etc.) but I have been told the UC520 will ignore this and rotate through all the ports. This seems to be the case as I only have 2 FXO ports active and it will choose either for outbound calls. ???
