10-14-2009
02:08 PM
- last edited on
03-25-2019
10:42 PM
by
ciscomoderator
I've searched the Cisco Web site and documentation and can't find any information or specifications for what I can connect to the MoH port. I have a Digital Messaging System with both a 600 ohm and an 8 ohm output. Which should I use to connect to the MoH port?
10-15-2009 07:11 AM
The UC500 MoH port is a standard 3.5-mm mini-jack.
Marcos
10-15-2009 07:41 AM
The size I found.
What I'm not finding is information such as:
1. Is it Mono or stereo
- I can fairly safely ASSUME its mono
2. When impendence does it have? Is it 8 ohms or 600 ohms or something else?
- If I plug in the incorrect impendence source it will not work correctly. Worst case i will 'short' the UC Mother board and burn it out. or the MoH source output amp. Best case it just won't work correctly.
11-10-2009 07:55 AM
Does anyone have an update for this question or should I call Cisco Support?
