ASA anyconnect issue with public pool
larbi farouk
we have an issue with asa firewall(9.5) when configuring Anyconnect such as that our public ip address are not configured on outside interface but as a pool for nat, we have private subnet with our service provider (/30) to our router ,and other private subnet (/30) between router and firewall
after configuration when we try to access via anyconnect we get a timeout problem, my question is if there is other config to do for this situation or the wan ip address should be on physical outside interface
thankyou.
Things are easier when the ASA has the public IP on it's outside interface. But it still should work in other setups. I would assume that you are doing something wrong with your NAT here.
Can you draw a diagram with your devices and where which addresses are located?
you can find in attachment the physical diagram
for NAT, actual I use for anyconnect a new ip address (not used for nat )
now how can redirect traffic from outside interface to wan ip address used for anyconnect.
should I apply translation from wan to lan address for anyconnect or nat rule are applied automatically
Well, I have no idea why a network is build in a way like this ...
But to make it work, the ISP (or whoever is responsible for the device that holds the public IPs) needs a static translation for one of the public IPs to your ASA WAN-address. Is that NAT (and corresponding access-control for tcp/443, ump/443) in place?
