VPN Tunnel between ASA 5525-X and ASA 5520
david-lima
Level 4
Level 4
Hi all,
I have an HQ site with a Cisco ASA 5525-X and a remote site with a Cisco ASA 5520. The point is that in the remote site I have an ADSL with a dynamic IP address. Is it possible to establish a VPN tunnel? I was trying to configure the "vpclient server" command but it is only supported in Cisco ASA 5505 and not in ASA 5520.
Thanks and regards.
David
Marvin Rhoads
We can create LAN-LAN VPNs where one end has a DHCP-assigned address. In such a setup, the main site uses a dynamic crypto map. There is a pretty old (but still mostly valid) example in the Cisco support site for the ASA: Link.
Here is a link to the relevant section in the current command reference.
Marvin Rhoads
Thanks Marvin, the VPN it is working now.
Best regards.
David
