11-19-2004 04:04 PM
We have a site-to-site VPN connection (PIX501-VPN3005)
Our PIX501 often has a problem like below:
Every 3~5 days, I will cant ping the inside interface of it but at the same I can ping the outside interface, then the VPN tunnel will break, we have to restart it manually, why it has this symptom? Does it because the PIX have a quality problem? Thanks
11-20-2004 01:09 AM
Hello tony,
Is browsing happening during this time ?? Are the nat translations happening ??
Is the PIX not responding during this time ? any error messages on the console ?
Have you enabled logging ?? please disable logging and see if this still happening.. the command to do this is "no logging on"..
do let us know...
11-21-2004 05:43 AM
Hi Please see my configuration:
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname fcngu001
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list toIPSEC permit ip 10.xx.x.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list toIPSEC permit ip 10.xx.x.0 255.255.255.0 172.16.0.0 255.240.0.0
access-list toIPSEC permit ip 10.xx.x.0 255.255.255.0 xxx.73.0.0 255.255.0.0
access-list doNotNAT permit ip 10.xx.x.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list doNotNAT permit ip 10.xx.x.0 255.255.255.0 172.16.0.0 255.240.0.0
access-list doNotNAT permit ip 10.xx.x.0 255.255.255.0 xxx.73.0.0 255.255.0.0
access-list toOutside permit icmp any any unreachable
access-list toOutside permit icmp any any echo-reply
access-list toOutside permit icmp any any time-exceeded
pager lines 24
logging on
logging buffered errors
logging trap informational
logging history informational
logging host inside xxx.xx.254.243
mtu outside 1500
mtu inside 1500
ip address outside 210.xx.xxx.220 255.255.255.248
ip address inside 10.xx.x.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list doNotNAT
nat (inside) 1 10.xx.x.0 255.255.255.0 0 0
access-group toOutside in interface outside
route outside 0.0.0.0 0.0.0.0 210.xx.xxx.217 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set novo esp-aes esp-md5-hmac
crypto map cngu 10 ipsec-isakmp
crypto map cngu 10 match address toIPSEC
crypto map cngu 10 set peer xxx.155.xxx.180
crypto map cngu 10 set transform-set novo
crypto map cngu interface outside
isakmp enable outside
isakmp key ******** address xxx.155.xxx.180 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet 10.0.0.0 255.0.0.0 inside
telnet xxx.73.0.0 255.255.0.0 inside
telnet timeout 5
ssh 217.xx.xx.129 255.255.255.255 outside
ssh timeout 5
management-access inside
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
11-22-2004 12:55 AM
Hi tony,
when the problem happens, whats the response on the console ? are you able to see the arp ? are you able to ping the local PCs from the console ? is browsing happening at that time ? the config seems ok.. you can though try removing logging, by doing "no logging on" command and remove all other commands with respect to logging. try this and see if your problem is solved.
All the best !!
11-22-2004 04:39 AM
Thanks, I have removed all the logging command and I will wait for at least one week to see if this problem is still exists.
Sorry, I can't see the information from console because this PIX is in our remote office.
Regarding arp, I can show arp when it's normal, but when it's time out, I will can't login and see arp.
The last thing, I don't understand 'browsing', could you please give me a detailed explanation about what is 'browsing'? Thanks a lot!
BR
11-22-2004 05:13 AM
hi tony,
By browsing, I meant "internet surfing" , ie the http access from the PC..
hope your problems get solved.. message us if your problem is still existing.. rate all replies if found useful...
11-23-2004 05:49 AM
Hi Thanks, I will continue to monitor it.
I have some other questions need your help:
1. If a PIX501 is a 50-licenses, does it mean that it can support up to 50 internal ip address to access outside simultaneously? Or it means there is up to 50 bi-direction session can pass this PIX simultaneously? Which one is right?
2. If a PIX501 is a 50-licenses device, how can I know the active used licenses (or available licenses remained) on this PIX?
