Dial-in Problem in 3745 with E1 R2 controller
raju
Hi !
I have a 3745 with E1 Connection and it was working fine . Since Yesterday,it's giving busy when user dials eventhough all the lines are free . If I reboot the Router, user can dial-in . After 5 minutes or like so, it again gives busy tone with no user connected and I had reboot the Router again to allow the calls .
Any idea ?.
Raju
marinos_g
Can you tell me the IOS you are using?
Maybe it could be an IOS bug problem...
It's worth a check!
Marinos
Thanks marinos...
It's ok now . The problem was with E1 line and ISP fixed it.
Raju
