ASA: AnyConnect with fix assignment between client PC and IP address
swscco001
Level 3
Level 3
Hello everybody,
our customer has a special requirement at his AnyConnect application with his
ASA5555 (OS 9.14(3)15).
They need a fix assignment between client PC and the assigned IP address,
independent of the user who will login.
I thought about a solution with a DHCP server that has a fix assignment between
MAC and IP address.
Is there a possibility to realize this anyhow?
Every idea or sample config is welcome!
Thanks a lot!
Bye
R.
Hi @swscco001 the ASA won't know about the connecting laptop's MAC address.
You can assign a static IP address by querying AD to deteremine if the AD user has been configured with a static IP address under the user's "Dial-in" properties, if not the user will be assigned an IP address defined under the VPN pool assigned to the group policy.
Examples for RADIUS or LDAP auth.
https://integratingit.wordpress.com/2017/01/01/cisco-asa-anyconnect-vpn-with-static-client-ip-address/
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/91831-mappingsvctovpn.html#anc17
