CISCO 1841 with SHDSL Problem?
INEM
I´am new in cisco WIC configuration. I have a CISCO 1841 with a interface: 1SHDSL v3 and i want to connect to my ISP over a PPoE encapsulation.
I just make the new interface connection in SDM, but the synchronism with the ISP not work. The ISP tell me that VPI/VCI is 0.35 and the annex is the A.
I live in the Europe, but i think that the annex A is for POTS lines and Annex B for ISDN, right?? My line is ADSL Analog.
My startup-configuration is that:
Router#show run
Building configuration...
Current configuration : 2974 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-2879799878
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2879799878
revocation-check none
rsakeypair TP-self-signed-2879799878
crypto pki certificate chain TP-self-signed-2879799878
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383739 37393938 3738301E 170D3131 30343233 32303532
  33345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 38373937
  39393837 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BE34 379A4D5D 1DA98B67 708AF8D4 221F1BE5 C5947EEA FF931EF4 37AD8A2C
  C786C8D9 88E97474 D32FE0F0 10C048B9 6F5DA580 55241E61 9B0D849A D9E7182A
  04D6C8E0 0C748DC7 0D8B4777 252CD4E1 01A1CEFC D57069CD C1B5E071 E591212D
  80BE3A50 9062884E 57F4BF0C C0EFBF12 6509E384 E1196B8B 11C42280 80806D4B
  F9290203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 06526F75 74657230 1F060355 1D230418 30168014 801FF21F
  B68B4902 F183264C 381B00FF 31E04AD1 301D0603 551D0E04 16041480 1FF21FB6
  8B4902F1 83264C38 1B00FF31 E04AD130 0D06092A 864886F7 0D010104 05000381
  810072E2 23CBEABC B0D8ED1B 09835CAD 6D4D92C7 31880AF1 B9EC00DC 12DBDC2B
  637FD4AB 39051AF3 04D3D948 180AB27A FFF66B33 6E44AB03 5280EC27 3C68C054
  B365F6E3 5272D96F 9BBBC96E 228CC9C7 84F3CC48 28479B47 D8ADD129 7BF495FF
  D8AFCA02 F8096B3C 581E68AA 16A00112 49FCED96 83DD2847 BA07F69D 9195248B EF31
        quit
username INEM privilege 15 secret 5 $1$2Jgp$bV.OuBughjgSIOLuCr6Kn16FP.
archive
log config
  hidekeys
controller DSL 0/0/0
mode atm
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description Conection to CISCO SDM
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1412
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface Dialer0
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname r353535
ppp chap password 0 xdfgdfg
ppp pap sent-username r353535 password 0  xdfgdfg
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Some one can help me please?
thanks
paolo bevilacqua
You are using the wrong type of interface, it cannot work.
You need HWIC-1ADSL. Nothing else will work,
Can you explain me please the reason of my WIC 1SHDSL-v3 not work in ADSL lines ?
Thank you,
Best Regards
Because, as explained before, and as the product name imples, it is an SHDSL interface, not an ADSL interface.
